Hi, I am a new member here also new to programming and arduino.
Currently, Im on working with my private project which leads to the dead end.
The idea is simple. The project consist of 6 button and 6 led.
Each button when pressed light up each led.
This is the simple part. Then the dead end is when I tried to make Push 2 button simultaneously
will light up certain led. As example,
When push button 1 and 2 simultaneously will light up led 3,4 and 5.
Here I attach my work sample.
int LED1 = 9;
int LED2 = 8;
int LED3 = 7;
int LED4 = 10;
int LED5 = 11;
int LED6 = 12;
int BUTTON1 = 1;
int BUTTON2 = 2;
int BUTTON3 = 3;
int BUTTON4 = 4;
int BUTTON5 = 5;
int BUTTON6 = 6;
void setup(){
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
pinMode(LED3,OUTPUT);
pinMode(LED4,OUTPUT);
pinMode(LED5,OUTPUT);
pinMode(LED6,OUTPUT);
pinMode(BUTTON1,INPUT);
pinMode(BUTTON2,INPUT);
pinMode(BUTTON3,INPUT);
pinMode(BUTTON4,INPUT);
pinMode(BUTTON5,INPUT);
pinMode(BUTTON6,INPUT);
digitalWrite(LED1,LOW);
digitalWrite(LED2,LOW);
digitalWrite(LED3,LOW);
digitalWrite(LED4,LOW);
digitalWrite(LED5,LOW);
digitalWrite(LED6,LOW);
void loop(){
if(digitalRead(BUTTON1) == HIGH){ // Alphabet "A"
digitalWrite(LED1,1);
}else{
digitalWrite(LED1,0);
if(digitalRead(BUTTON2) == HIGH){ //Alphabet "S"
digitalWrite(LED2,1);
digitalWrite(LED3,1);
digitalWrite(LED4,1);
}else{
digitalWrite(LED2,0);
digitalWrite(LED3,0);
digitalWrite(LED4,0);
if(digitalRead(BUTTON3) == HIGH){ //Alphabet"D"
digitalWrite(LED5,1);
}else{
digitalWrite(LED5,0);
if(digitalRead(BUTTON4) == HIGH){ //Alphabet"J"
}else{
if(digitalRead(BUTTON5) == HIGH){ //Alphabet "K"
}else{
if(digitalRead(BUTTON6) == HIGH){ //Alphabet "L"
}else{
if((digitalRead(BUTTON1) == HIGH) && (digitalRead(BUTTON2) == HIGH)){ //Alphabet "B"
digitalWrite(LED6,0);
}else{
if(digitalRead(BUTTON1) == HIGH && (digitalRead(BUTTON3) == HIGH)){ //Alphabet "C"
}else{
Tried this code and for single push it is working but when push 2 button simultaneously it is no effect.
I need help and advise.
Thank you and much appreciate sir.
