Ok, what would be the simplest way, without using delay to do the following
An input that turns on a LED
the LED is held on for say 5 seconds
If the input is hit again within the 5 secs it will restart the 5 sec timer thus keeping the led on and won't turn off until no input for 5 seconds.
Could be push a button, the led turns on a timer keeps it on for 5 secs, then it's hit again and timer is reset thus keeping the led on until no input is hit within 5 secs.
The problem my noob self is having is how to do the timing.
Ok, let me clear up some, I couldn't get that code to work, plus I'm not trying to do this in loop.
I have a function that turns on and off a pump. Instead of the pump turning off right after input off, i'd like to keep it on uncase there is another input that requires it to stay on.
So the function that tells the pump function on or off pump(0) or pump(1) and it just runs a switch and turns the pump on or off.
void pump(int sysPump){
switch(sysPump){
case 0:
digitalWrite(rlay9, HIGH); // HIGH TURNS OFF RELAY
case 1:
digitalWrite(rlay9, LOW); // LOW TURNS ON RELAY
I need the pump to keep running for 5 seconds in case another input requires it on. So just keeping the pump on for X time. I'm using 5 seconds, but that could be changed of course.
I hope this clears up what I'm trying to do.
I have a function that reads an analog reading, and if it's between set readings (high/low) it will kick the pump on. I need the pump to stay on in case another reading needs it, it just helps keep lag of the pump turning on and off down to a min.
Any way of changing up the pump function to keep the pump on for X time?
I have the millis thing working, and it does hold it on for the extra 5 seconds, but if another input uses it again, it doesn't reset the timer so it stays on another 5 secs continued. So when the 1st input turns it on, as soon as it's off it's turning off in 5 secs no matter what and then comes right back on if input active.
Not that the small pulse off would hurt anything, it's just that there is a off pulse for about 50ms.
switch(sysPump){
case 0:
jcurrentMillis = millis();
if (jcurrentMillis - jpreviousMillis >= jinterval == true ) {
digitalWrite(rlay9, HIGH); // LOW TURNS ON RELAY PUMP ON
// save the time when we displayed the string for the last time
jpreviousMillis = jcurrentMillis;
case 1:
digitalWrite(rlay9, LOW); // LOW TURNS ON RELAY PUMP OFF
I would like it if the "pump on" signal is given again within that 5 secs it just continues to stay on, like resets the 5 sec counter. I can't figure out how to reset the 5 sec counter if pumpon is called again.
putting previousMillis = currentMillis in the pump on switch fixed it. Now it stays on and the counter resets on every push of the button. Works perfect now thanks!
// PUMP OPS
switch(sysPump){
case 0: // turns off the pump
//digitalWrite(rlay9, HIGH); // HIGH TURNS OFF RELAY
case 1: // turns on the pump
digitalWrite(rlay9, LOW); // LOW TURNS ON RELAY Turns on the pump
