Push Botton Counter improvement code!
Hello everyone,
I need help, I downloaded the code to count and add a button and it works wonders. Except that it starts counting 1 by default, and when I modify the code it does not work anymore.
The other issue I need is that at a certain point, reset the counter to 0, and I do not know how to do it.
Welcome advice and help.
I share the code. Greetings.
Hola todos,
Necesito ayuda, bajé el código para contar y sumar un pulsador y funciona de maravilla. Escepto que inicia contando el 1 por default, y cuando modifico el código ya no funciona.
El otro tema que necesito es que en un punto determinado, resetee el contador a 0, y no se cómo lograrlo.
Bienvenidos los consejos y la ayuda.
Les comparto el código. Saludos.
// this constant won't change:
const int  buttonPin = A2;    // the pin that the pushbutton is attached to
const int ledPin = 9;       // the pin that the LED is attached to
// Variables will change:
int Cantidad = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT_PULLUP);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      Cantidad++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(Cantidad);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(10);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // turns on the LED every four button pushes by checking the modulo of the
  // button push counter. the modulo function gives you the remainder of the
  // division of two numbers:
  if (Cantidad % 4 == 0) {
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
}[code]
Push_Botton_180619.ino (1.63 KB)
Add an extra button or detect a long press to reset the counter.
Not sure why your code starts counting immediately.
buttonState and lastButtonState are initialized to zero in the declarations. Since buttonPin is INPUT_PULLUP then if the switch is not pressed buttonState will be assigned the value HIGH by the opening digitalRead(). buttonState and lastButtonState are now unequal.
