ı made a project with push button,limit swwitches and dc motors.I want to start calibration process when first push button pressed and stop calibration process first push putton press secondly. But when i pressed first push button serial monitor didnt write "calibration start".
if(kalibrasyonState == HIGH && lastkalibrasyonState == LOW){
Serial.println("calibrasyon start");
vanapositioncontrol();
int vanarole2State = digitalRead(vanarole2);
if(vanarole2State==HIGH){
Serial.println("vana pozsiyon kontrol edildi");
tartipositioncontrol();
int tartirole1State = digitalRead(tartirole1);
if(tartirole1==HIGH){
Serial.println("tartı pozsiyon kontrol edildi");
calibration();
Serial.println("kalibrasyon tamamlandı");
lastkalibrasyonState=kalibrasyonState;
Full code of project is here.
#include <HX711.h>
#include <TM1637Display.h>
#include "DualMC33926MotorShield.h"
#include "Wire.h"
#include <Keypad.h>
HX711 scale(A2, A3);
int paketboyutu = 0;
int a=0;
int b=0;
int c=0;
//int kalibrasyonState = 0;
int lastkalibrasyonState = LOW;
//int processState = 0;
int lastprocessState = LOW;
//int vanarole1State = 0;
//int vanarole2State = 0;
//int tartirole1State = 0;
//int tartirole2State = 0;
const byte ROWS = 4;
const byte COLS = 3;
const int kalibrasyon = 3;
const int process = 2;
const int vanarole1 = 14;
const int vanarole2 = 15;
const int tartirole1 = 5;
const int tartirole2 = 4;
//const int CLK = 5;
//const int DIO = 4;
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {11, 6, 7, 9};
byte colPins[COLS] = {10, 12, 8};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
DualMC33926MotorShield Motors;
//TM1637Display display(CLK, DIO);
// display.setBrightness(0x0a);
Motors.init();
// paketboyutu = GetNumber();
// Serial.println(paketboyutu);
pinMode(kalibrasyon, INPUT);
pinMode(process, INPUT);
pinMode(vanarole1, INPUT);
pinMode(vanarole2, INPUT);
pinMode(tartirole1, INPUT);
pinMode(tartirole2, INPUT);
int kalibrasyonState = digitalRead(kalibrasyon);
//int processState = digitalRead(process);
//int vanarole1State = digitalRead(vanarole1);
//int vanarole2State = digitalRead(vanarole2);
//int tartirole1State = digitalRead(tartirole1);
//int tartirole2State = digitalRead(tartirole2);
if(kalibrasyonState == HIGH ){
kalibrasyonState=LOW;
else{
kalibrasyonState=HIGH;
Serial.println("kalibrasyon başladı");
calibration();
Serial.print("paketboyutu:");
double weight=scale.get_units(10);
// display.showNumberDec(weight);
if(lastprocessState == HIGH && processState == LOW){
Serial.print("PROCESS BAŞLADI");
while(weight<paketboyutu){ //İF Mİ WHİLE MI??
vanageri(); //vana açılacak
menteseac120();
lastprocessState=processState;
void calibration(){
scale.power_down(); // put the ADC in sleep mode
delay(2000);
scale.power_up();
scale.set_scale(2280.f);
scale.tare();
void menteseac(){
Motors.setM1Speed(400);
void mentesekapa(){
Motors.setM1Speed(-400);
void menteseac120(){
Motors.setM1Speed(200);
void vanaileri(){
void vanageri(){
void vanapositioncontrol(){
while(vanarole2State==LOW){
vanaileri();
//vanarole2State = digitalRead(vanarole2)
void tartipositioncontrol(){
while(scale.get_units(10)!=0){ //tartının üzerinde malzeme varsa
menteseac120();
if(scale.get_units(10)==0){ //nerde kapanacağı önemli
while(tartirole1==LOW){ //menteşe kapalı pozşsyonda olmayabilir
mentesekapa();
if(tartirole2==HIGH){
for(int i=0;i<1;i++){
while(tartirole2==LOW){
menteseac(); //buraya da sayı gelebilir karışabilir
mentesekapa();
int GetNumber()
int num = 0;
char key = keypad.getKey();
while(key != '#')
switch (key)
case NO_KEY:
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
num = num * 10 + (key - '0');
case '*':
num = 0;
key =keypad.getKey();
return num;
