Push button/counter/relay sketch feeback
Hello,
I am trying to write a simple script that will watch an input which will receive a 5v signal which will keep increasing the counter variable roughly 1 every second. I setup an if loop to activate a relay when the counter reaches a certain number then deactivate the relay after a certain amount of time and then resetting the counter to start all over. I need this to run continually while its powered up. It seems to compile but I just want to get some feedback on the code before I upload and start testing.
I also attempted to get the arduino to send back the counter variable to the IDE but for some reason it only sends the word "counter=" back twice with no variable value after the "="
#define RELAY 6
#define input 1
int counter;
int buttonState;
counter = 0;
pinMode (input, INPUT);
pinMode(RELAY, OUTPUT);
digitalWrite(RELAY,LOW);
Serial.write("Counter=");
Serial.write(counter);
Serial.print('\n');
buttonState = digitalRead(input);
while(buttonState == HIGH) {
counter++;
delay(1000); //wait 1 second
if(counter>=2000){
digitalWrite(RELAY,LOW); // Turns ON Relays 1
delay(30000); //time to run pump *1000
digitalWrite(RELAY,HIGH); // Turns Relay Off
counter=0;
Use Serial.print rather than Serial.write. Serial.println adds a cr/lf.
Made a few adjustments, declared the value when initializing the variable and now it outputs the variable value when it prints, still only does it twice for some reason though.
#define RELAY 6
#define input 1
int counter=0;
int buttonState;
Serial.print("Counter=");
Serial.print(counter);
Serial.print('\n');
counter++;
if(counter>=2000){
counter=0;
Do you see the difference in these two pieces of code?
  while (buttonState == HIGH)
    counter++;
    counter++;
#define input 1
Pins 0 and 1 are used for serial communications.
Don't use 1, try 2 instead.
larryd:
    counter++;
    counter++;
Yes, moved the button state variable to inside the while loop. I assume the first is correct because wouldn't you need to rear the variable so it'll enter the while loop.
Inputs adjusted,
#define RELAY 6
#define input 2
int counter=0;
int buttonState;
 Serial.print('\n');
counter++;
  if(counter>=2000){
   counter=0;
"Yes, moved the button state variable to inside the while loop. I assume the first is correct because wouldn't you need to rear the variable so it'll enter the while loop."
Maybe you can have one outside and one inside. :wink:
counter++;
You are not understanding.
If you never update 'buttonState' inside the 'while' loop, please explain how you get out of it? :wink:
Oh damn, i created an infinite loop. Thanks!
Any other thoughts? I uploaded the new code and now its only giving the the "counter=0" once. I havent put a push button on it yet, though.
#define RELAY 6
#define input 2
int counter=0;
int buttonState;
 Serial.print('\n');
counter++;
  if(counter>=2000){
   counter=0;
Maybe you can have one outside 'and' one inside. :wink:
I did, forgot to attach the code to the latest post(updated).
Thanks again for the help!
