push button counter
Hi
i have a button connected to my arduino. i wanted to code a counter into my sketch, so once the button is pushed it adds 1 to the counter. i have to count from 0 to 23, and once it reaches 23 it goes back to zero and the counter starts again.
i hope someone can help me with this
thank you
You can modify this:
/*SwitchManager skeleton
 LarryD
 This sketch is to introduce new people to the SwitchManager library written by Nick Gammon
 The library handles switch de-bouncing and provides timing and state change information in your sketch.
 The SwitchManager.h file should be placed in your libraries folder, i.e.
 C:\Users\YourName\Documents\Arduino\libraries\SwitchManager\SwitchManager.h
 You can download the library at:
 http://gammon.com.au/Arduino/SwitchManager.zip    Thank you Nick!
 In this example we have 2 normally open (N.O.) switches connected to the Arduino - increment and decrement.
 The increment switch will also be used as a "Reset" switch if pressed for more than two seconds.
 The two switches are connected between GND (0 volts) and an Arduino input pin.
 The library enables pull-up resistors for your switch inputs.
 Pushing a switch makes its pin LOW. Releasing a switch makes its pin HIGH.
 The SwitchManager library provides 10ms de-bounce for switches.
 i.e. enum { debounceTime = 10, noSwitch = -1 };
 If you need more time, edit the SwitchManager.h file
 i.e. enum { debounceTime = 50, noSwitch = -1 }; //here it is changed to 50ms
#include <SwitchManager.h>
//object instantiations
SwitchManager myIncSwitch;
SwitchManager myDecSwitch;
unsigned long currentMillis;
unsigned long heartBeatMillis;
unsigned long heartFlashRate  = 500UL; // time the led will change state
unsigned long incShortPress   = 500UL; // 1/2 second
unsigned long incLongPress    = 2000UL;// 2 seconds
unsigned long decShortPress   = 500UL; // 1/2 second
const byte heartBeatLED       = 13;
const byte incSwitch          = 4; //increment switch is on Arduino pin 4
const byte decSwitch          = 5; //decrement switch is on Arduino pin 5
int myCounter;
  //gives a visual indication if the sketch is blocking
  pinMode(heartBeatLED, OUTPUT);
  myIncSwitch.begin (incSwitch, handleSwitchPresses);
  myDecSwitch.begin (decSwitch, handleSwitchPresses);
  //the handleSwitchPresses() function is called when a switch changes state
} //                   E N D  o f  s e t u p ( )
  //leave this line of code at the top of loop()
  currentMillis = millis();
  //some code to see if the sketch is blocking
  if (CheckTime(heartBeatMillis, heartFlashRate, true))
    //toggle the heartBeatLED
    digitalWrite(heartBeatLED,!digitalRead(heartBeatLED));
  //check to see what's happening with the switches
  //"Do not use delay()s" in your sketch as it will make switch changes unresponsive
  //Use BlinkWithoutDelay (BWD) techniques instead.
  myIncSwitch.check ();
  myDecSwitch.check ();
  //put other non-blocking stuff here
} //                      E N D  o f  l o o p ( )
//                          F U N C T I O N S
//                        C h e c k T i m e ( )
//Delay time expired function
//parameters:
//lastMillis = time we started
//wait = delay in ms
//restart = do we start timing again
boolean CheckTime(unsigned long  & lastMillis, unsigned long wait, boolean restart)
  //has time expired for this task?
  if (currentMillis - lastMillis >= wait)
    //should this start again?
    if(restart)
      //yes, get ready for the next iteration
      lastMillis += wait;
    return true; //the timer has timed out
  return false;  //the timer has not timed out
} //                 E N D   o f   C h e c k T i m e ( )
//                h a n d l e S w i t c h P r e s s e s( )
void handleSwitchPresses(const byte newState, const unsigned long interval, const byte whichPin)
  //You get here 'ONLY' if there has been a change in a switches state.
  //when a switch has changed state, SwitchManager passes this function 3 arguments:
  //"newState" this will be HIGH or LOW. This is the state the switch is in now.
  //"interval" the number of milliseconds the switch stayed in the previous state
  //"whichPin" is the switch pin that we are examining
  switch (whichPin)
    //are we dealing with this switch?
  case incSwitch:
    //has this switch gone from LOW to HIGH (gone from pressed to not pressed)
    //this happens with normally open switches wired as mentioned at the top of this sketch
    if (newState == HIGH)
      //The incSwitch was just released
      //was this a short press followed by a switch release
      if(interval <= incShortPress)
        Serial.print("My counter value is = ");
        myCounter++;
        if(myCounter > 1000)
          //limit the counter to a maximum of 1000
          myCounter = 1000;
        Serial.println(myCounter);
      //was this a long press followed by a switch release
      else if(interval >= incLongPress)
        //we could also have an upper limit
        //if incLongMillis was 2000UL; we could then have a window between 2-3 seconds
        //else if(interval >= incLongMillis && interval <= incLongMillis + 1000UL)
        //This could be used to change states in a StateMachine
        //We could increment the mycounter by 10 etc.
        //in this example however, we will just RESET myCounter
        myCounter = 0;
        Serial.print("My counter value is now RESET = ");
    //if the switch is a normally closed (N.C.) and opens on a press this section would be used
    //the switch must have gone from HIGH to LOW
      Serial.println("The incSwitch was just pushed");
    break; //End of case incSwitch
  case decSwitch:
      //The decSwitch was just released
      if(interval <= decShortPress)
        myCounter--;
        if(myCounter < 0)
          //don't go below zero
          myCounter = 0;
      Serial.println("The decSwitch switch was just pushed");
    break; //End of case decSwitch
    //Put default stuff here
    //default:
    //break; //END of default
  } //End of switch (whichPin)
} //      E n d   o f   h a n d l e S w i t c h P r e s s e s ( )
//                      E N D  O F  C O D E
