Hi everybody
I have got a small max7219 based 8x8 scrolling display, and I am trying to incorporate a push button interrupt to increase the brightness of the LEDs. The scrolling element of the code is fine, but I cannot get the bush button interrupt to work - please advise!
The code is shown below:
many thanks
#include <avr/pgmspace.h>
#include <LedControl.h>
const int DIN = 12; //DataIn pin (18)
const int CLK = 11; //Clock pin (17)
const int LOAD = 10; //Load pin (16)
const int numDevices = 1; //Number of MAX7219 LED Driver Chips (1-8)
const int buttonPin = 2; // the number of the pushbutton pin
int intensity = 0;
volatile int buttonState = LOW;
const long scrollDelay = 150;
prog_uchar font5x7 [] PROGMEM = { //Numeric Font Matrix (Arranged as 7x font data + 1x kerning data)
B00000000, //Space (Char 0x20)
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
6,
B01000000, //1
B11000000,
B01000000,
B01000000,
B01000000,
B01000000,
B11100000,
4,
B11111000, //5
B10000000,
B11110000,
B00001000,
B00001000,
B10001000,
B01110000,
6,
B01110000, //9
B10001000,
B10001000,
B01111000,
B00001000,
B00010000,
B01100000,
6,
B00000000, //:
B11000000,
B11000000,
B00000000,
B11000000,
B11000000,
B00000000,
3,
prog_uchar scrollText[] PROGMEM ={
" 9:51 "};
// * GLOBAL VARIABLES
unsigned long bufferLong [14] = {0}; //Buffer for scrolling text
LedControl lc=LedControl(DIN,CLK,LOAD,numDevices);
void setup(){
// initialize the pushbutton pin as an input:
attachInterrupt(buttonPin, stateChange, RISING);
for (int x=0; x<numDevices; x++){
lc.shutdown(x,false); //The MAX72XX is in power-saving mode on startup
lc.setIntensity(x,intensity); // Set the brightness to default value
lc.clearDisplay(x); // and clear the display
void loop(){
scrollMessage(scrollText);
void stateChange()
buttonState = !buttonState;
intensity++;
// Scroll Message
void scrollMessage(prog_uchar * messageString) {
int counter = 0;
int myChar=0;
do {
// read back a char
myChar = pgm_read_byte_near(messageString + counter);
if (myChar != 0){
loadBufferLong(myChar);
counter++;
while (myChar != 0);
// Load character into scroll buffer
void loadBufferLong(int ascii){
if (ascii >= 0x20 && ascii <=0x7f){
for (int a=0;a<7;a++){ // Loop 7 times for a 5x7 font
unsigned long c = pgm_read_byte_near(font5x7 + ((ascii - 0x20) * 8) + a); // Index into character table to get row data
unsigned long x = bufferLong [a*2]; // Load current scroll buffer
x = x | c; // OR the new character onto end of current
bufferLong [a*2] = x; // Store in buffer
byte count = pgm_read_byte_near(font5x7 +((ascii - 0x20) * 8) + 7); // Index into character table for kerning data
for (byte x=0; x<count;x++){
rotateBufferLong();
printBufferLong();
delay(scrollDelay);
// Rotate the buffer
void rotateBufferLong(){
unsigned long x = bufferLong [a*2]; // Get low buffer entry
byte b = bitRead(x,31); // Copy high order bit that gets lost in rotation
x = x<<1; // Rotate left one bit
bufferLong [a*2] = x; // Store new low buffer
x = bufferLong [a*2+1]; // Get high buffer entry
bitWrite(x,0,b); // Store saved bit
bufferLong [a*2+1] = x; // Store new high buffer
// Display Buffer on LED matrix
void printBufferLong(){
unsigned long x = bufferLong [a*2+1]; // Get high buffer entry
byte y = x; // Mask off first character
lc.setColumn(3,a,y); // Send row to relevent MAX7219 chip
y = (x>>24); // Mask off second character
lc.setColumn(2,a,y); // Send row to relevent MAX7219 chip
y = (x>>16); // Mask off third character
lc.setColumn(1,a,y); // Send row to relevent MAX7219 chip
y = (x>>8); // Mask off forth character
lc.setColumn(0,a,y); // Send row to relevent MAX7219 chip
