Push button once after delay no loop
I have a digispark attiny85 that I'm trying to have input a keystroke once when a computer is turned on and not loop. Is this something that is possible? All I've been able to find is starting the code with "void loop()" and setting a timer on it.
Is it possible to set another parameter to hit keystrokes once after a delay and it will do the same thing after a reboot or is looping keystrokes the only option?
Huh?
Hello
You can design and code a function to do this job.
What would I need to change in my code to only do it once and not on a loop?
  DigiKeyboard.sendKeyStroke(0);
  DigiKeyboard.sendKeyStroke(KEY_F2);
  DigiKeyboard.delay(60000);
try this
//  DigiKeyboard.delay(60000);
This works, but the pc I'm using doesn't drop power to USB like some on reboot sadly.
