Hi, I am having problems with my arduino push button, i have wired it up to two outputs (pin 12 & pin13) and i have the push button connected to (pin7).
I basically need the program to:
When the Arduino is powered up the motors do not turn
When the button is pressed the motors start their forward and backwards turning.
The motors should continue to turn when the button is released.
If the button is pressed again the motors should stop.
The motors should stay stopped when the button is released.
This should repeat i.e. pressing the button should start the motors again etc.
I'm missing the problem... All I see is a program request. We have a different section for that.
But if you write it yourself that's even better! But then you have to show the program, show a diagram (because really, only connecting a button to pin7 will never ever do something (at least not what you want) because a switch has at least two connections for a reason and motors don't come out of thin air) and a full problem description (doesn't work doesn't cut the mustard).
