push button recomendations
Greetings, I am having trouble finding a source for a particular button I'd like to use and am curious if anyone on this forum might know a good source for push buttons. I am looking for a push button that is not board mounted, has a removable plastic cover (allowing me to print custom labels), and has an LED backlit source that I can control via code. The size range I'd like is anywhere between 1.5cm and 2.5cm. I don't know what you call it but this button should not stay depressed when pressed. It should be a momentary so it pops back out when the finger is removed.
I am a newbie with this and could use a good source for buttons. Thank you.
-cablet
Problem is that that sort of button is quite expensive. Have a look at this list:- http://uk.farnell.com/jsp/search/results.jsp?N=500006+1000190&Ns=PRICE_PLS_006_PRICE1|0&Ntk=gensearch_001&Ntt=push+button+illuminated&Ntx=
It's the first of a lot of pages although they are sorted in price order.
Oddly enough it is called a momentary push button. ;)
If you want to spend a whole lot on a button, these LCD screen buttons look pretty cool
http://www.sparkfun.com/commerce/product_info.php?products_id=8492
If you're in the U.S., allelectronics.com has lots of lighted pushbutton switches.
