Hi every one yet another newbie here, I will try to not be to much of a pain in the but. So what I'm trying to do is simple except I can't figure out the best way to do it. Im working on an art project and I need to sequentially turn a relay on, delay, and then turn of. The next time the button is pressed relay #2 turns on,delays,and turns off.followed by relay #3 and so on. I need help withthe programming,how the heck do I accomplish this. Thanks and sorry to be that guy.
The example StateChangeDetection would be a good place to start. That sketch should give you an idea how it's done.
Hello I am writing a program which will do the cause hopefully its a simple code:
it should work perfectly incase it doesn't work do not hesitate to message.
int relay1=5; //relay pins
int relay2=6;
int relay3=7;
int button= 12; //button must be connected to 5v pin to digital pin 12
int count=0 ; //to store values how many times it has been pressed.
pinMode(relay1, OUTPUT);
int swtch = digitalRead(button);
int count = swtch+1;
if(count=1)
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
if(count=2)
digitalWrite(relay1, HIGH);
delay(2000);
if(count=3)
digitalWrite(relay2, HIGH);
delay(2000);
if(count=4)
digitalWrite(relay3, HIGH);
delay(2000);
count==0;
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
You could use
switch case
instead of a line of if statements
https://www.arduino.cc/en/Reference/SwitchCase
Thanks.. Tom..
@kjp_Durgesh: please stop doing this.
It is polite (or at least customary) to qualify code that even if it compiles, clearly does not perform as a reasonable person would expect as "uncompiled and untested".
Your stream-of-conciousness programming helps no-one.
The lack of code tags is secondary.
@kjp_Durgesh you need to re-read the man pages on = vs == for a start.
Your varable count will never go higher as 2.
A digitalRead will give you high or low (0 or 1).
int count = swtch+1; // results in 1 or 2
Please also read the comment from ardy_guy
