Hey everyone,
So I am trying build a counter that uses a d/c motor and and a lazer with a photo resistor to count the rotations of of a disc that turns. Basically, there is a disc attached to a motor shaft that turns when the motor is turned on. The photo resistor will count how many times the lazer hits it and keep track of the data. I want the motor to run and the counter to start taking in data for 60 seconds after pushing a button, then stop the motor and data intake after 60seconds. I have a code but want to know if the timer is correct on it. Thanks for the help.
if(countPin==HIGH){ //starts counter for photoresistor
11 is not equal to HIGH, so this statement will never evaluate to true.
pinMode(countPin,OUTPUT);
What, exactly, is connected to this pin?
if (flag=1){
Assigning the value 1 to flag in an if statement rarely makes sense.
unsigned long timePassed=timePassed+(currentTime-pastTime);
Creating a local variable with the same name as a global variable is rarely a good idea. Using the global variable in the definition of the local variable is DEFINITELY a crappy idea.
Having the local and global variables have different types is definitely a bad idea.
if(timePassed>=0);
digitalWrite(motorPin, LOW);
digitalWrite(countPin,LOW);
flag=0;//change flag variable again
Useless curly braces are not a good idea.
The if statement is pointless. If timePassed is greater than 0, do nothing (;). Otherwise, do nothing. Why bother testing?
The random indenting in your code is not a good idea. Use Tools + Auto Format to fix that.
