Hello, Can anyone help me with a piece of code to control a servo motor? I want to press the push button attached on pin 4, then the servo rotate 90 degrees, and the wait 10 seconds before going back to 0 degrees.
Code that seems to be close to what you describe.
//zoomkat servo button test 7-30-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
Servo servo1;
pinMode(button1, INPUT);
servo1.attach(7);
digitalWrite(4, HIGH); //enable pullups to make pin high
press1 = digitalRead(button1);
if (press1 == LOW)
servo1.write(160);
delay(2000);
servo1.write(20);
Thank you Zoomkat, I actually just found your code and changed it a little to work for my needs. My new problem is adding the one-wire input 4x4 keypad to unlock the servo as well as this piece of code. Any suggestions?
jrugg8028:
Did you get any example code for using the keypad?
Which keypad - post a link to its datasheet?
...R
