Push Button Stepper Motor
Hello everyone,
I have been working on a program that will activate a stepper motor when a push button is pressed. The program itself works without the if else statement for the push button. I will attach the code below. I would appreciate it if someone could explain what I am doing wrong when I add the push button into the program.
Functions.ino (1.41 KB)
Tutorial_StepperMotor.ino (1.32 KB)
It is easier to view your code if you post it in Code tags, rather than making anyone who wishes to view it download it.
But thank you for posting your code.
	PURPOSE:	Running a stepper motor with the Arduino
	Created by      Rudy Schlaf after a sketch by Sam Leong
	DATE:		1/2014
#define pin1  8//these are the Arduino pins that we use to activate coils 1-4 of the stepper motor
#define pin2  9
#define pin3  10
#define pin4  11
#define PB1  4 //this id the aarduino pin we are using that connects the pushbutton to the circuit//
#define delaytime 8  //delay time in ms to control the stepper motor delaytime.
                      //Our tests showed that 8 is about the fastest that can yield reliable operation w/o missing steps
  // initialize the 8 pin as an output:
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
  pinMode(pin3, OUTPUT);
  pinMode(pin4, OUTPUT);
  pinMode(PB1, INPUT);
void loop(){
  if (PB1 == HIGH)
  int numberOfSteps = 64;
  step_OFF();         //turning all coils off
  while(numberOfSteps>0){
    forward();        //going forward
    numberOfSteps -- ;//counting down the number of steps
  delay(2000);
  numberOfSteps = 64;
    backward();       //going backward
  delay(2000);
//these functions set the pin settings for each of the four steps per rotation of the motor (keepp in mind that the motor in the kit is geared down,
//i.e. there are many steps necessary per rotation
void Step_A(){
  digitalWrite(pin1, HIGH);//turn on coil 1
  digitalWrite(pin2, LOW);
  digitalWrite(pin3, LOW);
  digitalWrite(pin4, LOW);
void Step_B(){
  digitalWrite(pin1, LOW);
  digitalWrite(pin2, HIGH);//turn on coil 2
void Step_C(){
  digitalWrite(pin3, HIGH); //turn on coil 3
void Step_D(){
  digitalWrite(pin4, HIGH); //turn on coil 4
void step_OFF(){
  digitalWrite(pin1, LOW); //power all coils down
//these functions run the above configurations in forward and reverse order
//the direction of a stepper motor depends on the order in which the coils are turned on.
void forward(){//one tooth forward
  Step_A();
  delay(delaytime);
  Step_B();
  delay(delaytime);
  Step_C();
  delay(delaytime);
  Step_D();
  delay(delaytime);
void backward(){//one tooth backward
  Step_D();
  delay(delaytime);
  Step_C();
  delay(delaytime);
  Step_B();
  delay(delaytime);
  Step_A();
  delay(delaytime);
How do you have the push-button wired?
It is usually easiest to use pinMode(pin, INPUT_PULLUP); and connect the switch between the pin and GND. But then you get a LOW when the button is pressed.
You don't need the ELSE stuff.
...R
There are an awful lot of delays in there.
Can you tell us what exactly isn't working, and in what way it isn't working?
I have a push button wired with a separate power supply. The output of the button is located in pin 4 of the arduino board. I ran the program and when I pressed the button (made it HIGH) nothing happened. If I were to remove the if statement for the push button the program turns the motor the way I want it to. I cannot find the way to add the push button into the code. In regard to the delays, they work fine and are not the problem. Thanks to everyone who is responding. I really appreciate it.
Schematic? Hand-drawn is OK.
Is there a pull-down resistor on pin 4? It is more typical to use the internal pullup and have the switch pull to ground.
What separate power supply is on the pushbutton, and why? What voltage? Common ground?
In any case, you've defined PB1 as a constant of 4 for the pin number, then attempted to use PB1 as a variable. It will always be 4.
http://arduino.cc/en/pmwiki.php?n=Reference/Define
Example
#define ledPin 3
// The compiler will replace any mention of ledPin with the value 3 at compile time.
So you are asking if 4 is equal to High (1), and it never is.
I see no digitalRead in there, either. So you are never reading the state of pin 4.
