Push Button Switch, To Blink Led.
I want to make A push button, that when held down it would make, one led go on for 3 sec. then go off. Even if the switch is still held down.....
The code, I tried to make work is this. I thought to use A (while(.....)). It didn't work.
int buttonPin = 2;     // the number of the pushbutton pin
int ledPin =  13;      // the number of the LED pin
int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    digitalWrite(ledPin, HIGH);
    delay (300);
   while(buttonState == LOW);
  else {
    digitalWrite(ledPin, LOW);
Try: Note, add code to de-bounce your switch, I'll leave that up to you.
boolean ledOn = false;
  digitalWrite(buttonPin, HIGH);   // turn on pullup
  if (buttonState == HIGH && ledOn == false)
    ledOn = true;
  if (ledOn == true)
    delay(3000);
    ledOn = false;
  while (digitalRead(buttonPin))
    ;  // stay here as long as the button is pushed i.e. HIGH
    delay (300);
300 milliseconds doesn't equal 3 seconds.
You only arrive at this point in the code because buttonState is HIGH, how could it then be low if you don't read the button again?
