Push button Switches Won't work
Total noob; sooo new, that even digging through the forums is hard to comprehend. So apologies and thanks you's right away.
This program is a beginner project that when the one button is pushed it activates the motor for 4 seconds and then changes the state of the leds. when a second button is pressed it does the reverse.
I modified a simple push button switch from the reference section here but can't get them to actually work.
I've run the check in the IDE and it's not throwing any errors its just not working.
tinkerCAD link: Circuit design Copy of Launch Bay Door Control | Tinkercad
Please HALP! lol
J
Did you use INPUT_PULLUP or add a pullup or pulldown resistor to the button?
OOPS forgot the the code if you don’t use tinkerCAD.
<// C++ code
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
const int MOTOR_CLOSE=11;//"motor_forward" from other
const int MOTOR_OPEN=10;//"motor_back" from other
int RED_LIGHT= 14;
int ORANGE_LIGHT= 15;
int GREEN_LIGHT= 16;
const int BUTTON_OPEN= 9;
const int BUTTON_CLOSE= 8;
int buttonStateONE = 0;
int buttonStateTWO = 0;
  lcd.begin(16, 2);
  pinMode(MOTOR_CLOSE, OUTPUT);
  pinMode(MOTOR_OPEN, OUTPUT);
  pinMode(RED_LIGHT, OUTPUT);
  pinMode(ORANGE_LIGHT, OUTPUT);
  pinMode(GREEN_LIGHT, OUTPUT);
  pinMode(BUTTON_OPEN, INPUT);
  pinMode(BUTTON_CLOSE, INPUT);
  digitalWrite(RED_LIGHT, HIGH);
  digitalWrite(ORANGE_LIGHT, HIGH);
  digitalWrite(GREEN_LIGHT, HIGH);
  lcd.setCursor(1,0);
  lcd.print("Comand&Control");
  lcd.setCursor(0,1);
  lcd.print("Launch Bay Doors");
  delay(3000);//CHANGE ME FOR FINAL TIMING 3-6s?!!!!
  lcd.clear();
  digitalWrite(ORANGE_LIGHT, LOW);
  digitalWrite(GREEN_LIGHT, LOW);
  lcd.setCursor(0, 0);
  lcd.setCursor(3,1);
  lcd.print("**CLOSED**");
  delay(500);//CHANGE ME FOR FINAL TIMING 2s?!!!!
  buttonStateONE = digitalRead(BUTTON_OPEN);
  buttonStateTWO = digitalRead(BUTTON_CLOSE);
  while (RED_LIGHT=HIGH){
  lcd.clear();
  lcd.setCursor(3,1);
  delay(2000);
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print("Press 1 to Open");
  delay(3000);
if (buttonStateONE == HIGH) {
  lcd.clear();
  lcd.print("OPENING!");
  digitalWrite(MOTOR_OPEN, HIGH);
  digitalWrite(RED_LIGHT, LOW);
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  lcd.print("**OPEN**");
  digitalWrite(MOTOR_OPEN, LOW);
  delay (1500);
  while (GREEN_LIGHT=HIGH){
  lcd.clear();
  lcd.setCursor(3,1);
  lcd.print("***OPEN***");
  delay(2000);
  lcd.clear();
   lcd.print("GO GO GO");
    delay(1500);
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print("Press 2 to Close");
  delay(3000);
if (buttonStateTWO == HIGH) {
  lcd.clear();
  lcd.print("CLOSING!");
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  delay (1500);
push down resistor I believe.
And when you did post it uou did not use code tags
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
what is happening when you press the button? nothing?
nothing.
sorry i thought these were the tags “<>”
…an unrelated problem is my eyes are burning out. reading on my laptop is becoming very problematic.
are the leds lighting up?
  while (GREEN_LIGHT = HIGH)
    lcd.clear();
    lcd.setCursor(3, 1);
    delay(2000);
    lcd.clear();
    delay(1500);
    lcd.clear();
    lcd.setCursor(0, 1);
    delay(3000);
= does not do a comparison
Also, as GREEN_LIGHT does not change in this while loop how will it ever end ?
the void setup works exactly like I want it to, and the fist 'while' loop also works. its after where
lcd.clear();
delay(4000);
lcd.clear();
lcd.setCursor(1,1);
lcd.print("OPEN");
delay (1500);
Both while loops use = instead of ==
They don't work
No code tags again !
ack. my bad. sorry again.
wrong button.
Oh my goodness. Thank you;; that's progress! The whole loop runs now.
What im trying to get it to do now:
is getting it to stop between 'open' and close.
And I straight up am very confused as to which control command does this.
// C++ code
int RED_LIGHT= 14;
  lcd.begin(16, 2);
  lcd.setCursor(1,0);
  lcd.setCursor(0,1);
  lcd.clear();
  lcd.setCursor(3,1);
  while (RED_LIGHT==HIGH){
  lcd.clear();
  lcd.setCursor(3,1);
  delay(2000);
  lcd.clear();
  lcd.setCursor(0,1);
  delay(3000);
  lcd.clear();
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  delay (1500);
  while (GREEN_LIGHT==HIGH){
  lcd.clear();
  lcd.setCursor(3,1);
  delay(2000);
  lcd.clear();
    delay(1500);
  lcd.clear();
  lcd.setCursor(0,1);
  delay(3000);
  lcd.clear();
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  delay (1500);
GREEN_LIGHT is a pin, you will have to read it to know if it's high or low; that will work on AVR based Arduinos, not sure about others.
ok this is close I think; I just need to figure out how to make an 'int' at the very beginning work with the digitalREAD
// C++ code
int RED_LIGHT= 14;
  lcd.begin(16, 2);
  lcd.setCursor(1,0);
  lcd.setCursor(0,1);
  lcd.clear();
  lcd.setCursor(3,1);
    RED_LIGHT = digitalread (RED_LIGHT);
    GREEN_LIGHT = digitalread (GREEN_LIGHT);
  lcd.clear();
  lcd.setCursor(3,1);
  delay(2000);
  lcd.clear();
  lcd.setCursor(0,1);
  delay(3000);
  lcd.clear();
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  delay (1500);
  lcd.clear();
  lcd.setCursor(3,1);
  delay(2000);
  lcd.clear();
    delay(1500);
  lcd.clear();
  lcd.setCursor(0,1);
  delay(3000);
  lcd.clear();
  digitalWrite(MOTOR_CLOSE, HIGH);
  delay(4000);
  lcd.clear();
  lcd.setCursor(1,1);
  digitalWrite(MOTOR_CLOSE, LOW);
  delay (1500);
I did this and now obviously there is a conflict; how can i serrate them? and still have the pin as an output and read its own state?
// C++ code
const int RED_LIGHT= 14;
const int ORANGE_LIGHT= 15;
const int GREEN_LIGHT= 16;
int RED_LIGHT= 0;
 int GREEN_LIGHT=0;
You can read the state of an output pin using digitalRead()
Awesome! Thank you.
this is what I came up; with a lttle more help from my prof.
// C++ code
const int MOTOR_CLOSE = 11;  //"motor_forward" from other
const int MOTOR_OPEN = 10;   //"motor_back" from other
const int RED_LIGHT = 14;
const int ORANGE_LIGHT = 15;
const int GREEN_LIGHT = 16;
const int BUTTON_OPEN = 9;
const int BUTTON_CLOSE = 8;
int DOOR_STATUS=0;      //Closed=0, Opening =1, Closing=2, Open=4
  lcd.begin(16, 2);
  lcd.setCursor(1, 0);
  delay(3500);  //CHANGE ME FOR FINAL TIMING 3-6s?!!!!
  lcd.clear();
  lcd.setCursor(2, 1);
  lcd.print("***CLOSED***");
  delay(2500);  //CHANGE ME FOR FINAL TIMING 2s?!!!!
  while (DOOR_STATUS==0) {//while the door is closed
    lcd.clear();
    delay(2000);
    lcd.clear();
    unsigned long start=millis();
    while(digitalRead(BUTTON_OPEN==LOW)&&(millis()-start<300));
    if (digitalRead(BUTTON_OPEN) == HIGH) {
      DOOR_STATUS=1;    //change state to opening
  if (DOOR_STATUS=1) {  //the door is opening
    lcd.clear();
    lcd.print("***OPENING!***");
    delay(4000);//"door" takes 4s to open
    lcd.clear();
    delay(2000);
    DOOR_STATUS=4;   //the door is open
  while (DOOR_STATUS==4) {  //while the door is fully open
    lcd.clear();
    delay(2000);
    lcd.clear();
    lcd.print("*  STARBUCK IS *");
    lcd.print("CLEAR FOR LAUNCH");
    delay(2500);
    lcd.clear();
    lcd.print("*GO GO GO*");
    delay(2000);
    lcd.clear();
    while(digitalRead(BUTTON_CLOSE==LOW)&&(millis()-start<300));
    if(digitalRead(BUTTON_CLOSE)==HIGH){
      DOOR_STATUS=3; //the door is closing
   //add additional LED on/off here
  if (DOOR_STATUS=3) {  //if the door is closing
    lcd.clear();
    lcd.setCursor(1,0);
    lcd.print("***CLOSING!***");
    delay(4000);//"door" takes 4s to close.
    lcd.clear();
    delay(1500);
    DOOR_STATUS=0;   //the door is closed
if (DOOR_STATUS=1)
if (DOOR_STATUS=3)
Again ?
You need to try much harder.
