I'm trying to use a Push button to start the code. For example when the button is pushed the code will make the LED's light up back and forth and when the button is pushed again the sequence is stopped. I've debounced the push button and add the code to do this sequence. However when i push the button only one LED turns on and it won't turn off if the button is pushed again. I was wondering if someone could give me guidance as i've been struggling for a long time.
int delayTime =40;
int currentLED = 6; //a variable to store which LED we are currently
int currentLED1 =0;
int dir = 1; //A variable to store the direction of travel
int dir1 =1;
long timeChanged = 0; //A variable to store the last time we changed something
long timeChanged1 = 0;
byte ledPin[] = {4,5,6,7,8,9,10,11,12,13}; //An array to hold the value for each LED pin
for (int i=0; i<10; i++){
pinMode(ledPin[i],OUTPUT);
timeChanged = millis(); //Record the tieem once the setup has completed
if((millis()-timeChanged)>delayTime){ //Cheack whether it has been long enough
for (int i=5; i<10; i++) {
digitalWrite(ledPin[i],LOW); // turn all the LEDs off
digitalWrite(ledPin[currentLED],HIGH); //light the current LED
currentLED= currentLED - dir; //increase the direction value (up or down)
if (currentLED ==9) {
dir =1;
if(currentLED == 5){ //If we are at the end of a row, change direction
dir =-1;
timeChanged = millis(); //Store the current time as the time we last changed LEDS
if ((millis()-timeChanged1)>delayTime){
for (int i=0; i<5; i++){
digitalWrite(ledPin[currentLED1],HIGH);
currentLED1 = currentLED1 + dir1;
if (currentLED1 == 4){
dir1 = -1;
if(currentLED1 ==0){
dir1 = 1;
timeChanged1=millis();
}[int delayTime =40;
int currentLED1 =0;
int dir1 =1;
dir =1;
dir =-1;
dir1 = -1;
dir1 = 1;
}[code]
There is a difference between detected a button being held down and detecting "button just activated". Make shure You detect the latter. Than create a logical flip-flop that changes state when "button just pressed" has occured.
sorry i post the wrong code. Here is the actual code
int delayTime =40;
int PushButton =3;
int currentLED1 =0;
int dir1 =1;
int ledState =LOW;
int buttonState = 0;
int lastButtonState =1;
unsigned long lastDebounceTime =0;
unsigned long debounceDelay =50;
pinMode (PushButton, INPUT);
int reading = digitalRead(PushButton);
if (reading != lastButtonState){
lastDebounceTime = millis();
if((millis()-lastDebounceTime)>debounceDelay){
if(reading != buttonState){
buttonState = reading;
if (buttonState == HIGH){
ledState =!ledState;
dir =1;
dir =-1;
dir1 = -1;
dir1 = 1;
Duplicate threads moved to same section and merged
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
CrossRoads:
You need a 'flag' in there to tell the code the sequence is active or not.
I think ledState would do that, but you don't do anything with it.
For example,
if( ((millis()-timeChanged)>delayTime) && (ledState == 1)){ //Cheack whether it has been long enough
Put it in here too
Thank you for your response! I've done as you've instructed and it's halfed worked. The code will start but when i push the button again to stop the code I get no response and the lights keep running.
If you just want to turn things off when the button is pushed
const unsigned long delayTime = 40;
const int PushButton = 3;
int currentLED;
int lastButtonState = 1;
unsigned long debounceDelay = 50;
unsigned long timeChanged = 0; //A variable to store the last time we changed something
const byte ledPin[] = {4, 5, 6, 7, 8, 9, 10, 11, 12, 13}; //An array to hold the value for each LED pin
const byte nPins = sizeof(ledPin) / sizeof(ledPin[0]);
bool isRunning = false;
for (int i = 0; i < nPins; i++) {
pinMode(ledPin[i], OUTPUT);
timeChanged = millis(); //Record the time once the setup has completed
if (reading != lastButtonState) {
if (buttonState == HIGH) {
isRunning = !isRunning;
if ( isRunning == false ) {
// turn everything off
digitalWrite(ledPin[i], LOW);
// start lights
currentLED = 0;
delay(delayTime);
lastButtonState = reading;
if ( !isRunning ) {
return;
//Check whether it has been long enough
if ((millis() - timeChanged) >= delayTime) {
digitalWrite(ledPin[currentLED], LOW); // turn off current
currentLED += dir;
if ( dir > 0 ) {
// check for upper limit
if ( currentLED >= nPins ) {
currentLED = nPins - 1;
dir = -1;
// check for lower limit
if ( currentLED < 0 ) {
dir = 1;
currentLED = 0;
digitalWrite(ledPin[currentLED], HIGH); //light the current LED
const byte PushButton = 3;
byte currentLED = 6; //a variable to store which LED we are currently
byte currentLED1 = 0;
byte ledState = LOW;
byte buttonState = 0;
byte lastButtonState = 1;
int dir1 = 1;
unsigned long timeChanged1 = 0;
unsigned long lastDebounceTime = 0;
unsigned long switchMillis;
for (int i = 0; i < 10; i++)
} //END of setup()
checkSwitches();
if (ledState == HIGH && millis() - timeChanged > delayTime)
for (int i = 5; i < 10; i++)
digitalWrite(ledPin[i], LOW); // turn all the LEDs off
currentLED = currentLED - dir; //increase the direction value (up or down)
if (currentLED == 9)
dir = 1;
if (currentLED == 5) //If we are at the end of a row, change direction
dir = -1;
if (ledState == HIGH && millis() - timeChanged1 > delayTime)
for (int i = 0; i < 5; i++)
digitalWrite(ledPin[currentLED1], HIGH);
dir1 = -1;
if (currentLED1 == 0)
dir1 = 1;
timeChanged1 = millis();
} //END of loop()
void checkSwitches()
if (millis() - switchMillis < 50)
//not time to read the switches
return;
switchMillis = millis();
byte reading = digitalRead(PushButton);
if (reading == lastButtonState)
return;
//update to the new state
if (reading == HIGH)
ledState = !ledState;
} //END of checkSwitches()
