Push button to start and reset loop
Need help integrating a push button into the following program that will make the loop start, reset, each time the button is pressed.
//Arduino Code For the Piezo Buzzer And Light Synchronization
// Set up of digital pins and song length as measured per musical note
const int RED_PIN = 9;
const int GREEN_PIN = 10;
const int BLUE_PIN = 11;
const int buzzerPin = 12;
const int songLength = 99;
// Below are defined notes and their respective frequencies(Hz) that the piezo buzzer can output
// Frequency values are from: http://www.seventhstring.com/resources/notefrequencies.html
char names = {‘D’, ‘E’, ‘F’, ‘G’, ‘A’, ‘B’, ‘C’, ‘d’, ‘e’, ‘f’, ‘g’, ‘a’, ‘b’, ‘c’};
int frequencies = {587, 659, 699, 784, 880, 988, 1047, 1175, 1319, 1397, 1568, 1760, 1976, 2093};
// The following notes and their lengths have been extracted from a music sheet with
// the help of background knowledge in interpreting music
// Jingle Bells music sheet from: http://pianoandsynth.com/jingle-bells-piano/
char notes = “eeeeeeegCdefffffeeeeeddedgeeeeeeegCdefffffeeeeggfdCGedCGGGGedCAAfedBggfdeGedCGGGGedCAAfedgggggagfdC”;
// Eighth notes are defined as 1’s, quarter notes as 2’s, half notes as 4’s and so on
int beats = {2,2,4,2,2,4,2,2,3,1,8,2,2,3,1,2,2,2,1,1,2,2,2,2,4,4,2,2,4,2,2,4,2,2,3,1,8,2,2,3,1,2,2,2,1,1,2,2,2,2,8,2,2,2,2,6,1,1,2,2,2,2,8,2,2,2,2,8,2,2,2,2,8,2,2,2,2,6,1,1,2,2,2,2,8,2,2,2,2,2,2,2,1,1,2,2,2,2,8};
// Used to define the “speed” of the song
int tempo = 100;
pinMode(RED_PIN, OUTPUT); // Configured Arduino pins are used to drive the
pinMode(GREEN_PIN, OUTPUT); // RGB LED and buzzer as outputs
pinMode(BLUE_PIN, OUTPUT); // and pushbutton as an input
pinMode(buzzerPin, OUTPUT);
// Defined loop that steps through each note specified
int i, duration; // Variable i & duration defined
for (i = 0; i < songLength; i++) // Step through each note of the songs’ length
duration = beats * tempo; // Duration defines the length of the note or rest in ms
_ if (notes == ’ ')_
* { // If statement used to distinguish between rests and notes*
* delay(duration);*
* } // Pause for the duration of the rest*
* else // Otherwise, play the note specified*
_ tone(buzzerPin, frequency(notes*), duration);
if (frequency(notes) <= 1047) // Function to play a note on the piezo buzzer*
* // For frequencies lower than 1047 Hz*
* {_
digitalWrite(RED_PIN, HIGH); //Turn on Red LED and hold for duration of note*
* delay(duration);*
_ else if (frequency(notes*) <= 1319) // For frequencies lower than 1319 Hz*
* {_
digitalWrite(GREEN_PIN, HIGH); // Turn on Green LED and hold for duration of note*
* delay(duration); *
* else // For any frequency higher than 1319 Hz*
* digitalWrite(BLUE_PIN, HIGH); //Turn on Blue LED and hold for duration of note*
* delay(duration);*
* digitalWrite(RED_PIN, LOW); // After the notes duration turn off the LED*
* digitalWrite(GREEN_PIN, LOW); // This applies to the LED that was on*
* digitalWrite(BLUE_PIN, LOW);
_ delay(tempo/2); // Brief pause between notes ; avoid overlapping*
while(true)
{ // Function serves to stop the song from looping forever*
* noTone(buzzerPin); // Stops the song after running through once*
* digitalWrite(RED_PIN, LOW); // Turns off the LEDs*
digitalWrite(BLUE_PIN, LOW);*
} // The function below takes a note character, and returns the*
* // corresponding frequency in Hz for the tone() function*
int frequency(char note)
int i; // Variable i defined
const int numNotes = 14; // Number of notes stored which is 14 (2 octaves)
for (i = 0; i < numNotes; i++) // For loop is used to search through the letters
if (names == note) // If this is a specified note
return(frequencies); // Return the frequency*
return(0); // Otherwise don’t return anything
CHRISTMAS.PROJECT.JG.ino (5.49 KB)*_
Do you know how to read the state of an input ?
Have a look at the StateChangeDetection example in the IDE to see how to make something happen when a button [u]becomes[/u] pressed. Note that is different to doing something when the button [u]is[/u] pressed.
We appreciate the feedback, but we decided to try something different
