Push button to switching Led effects
Ok. So this more complicated than I was thinking.
It's not really complicated. It just takes a lot of time.
My thinking was going this way(sorry if this will looks ridiculous, but I'm not yet on this level). Using this part of code.
#define BUTTON_PIN 2
#define PIXEL_PIN 6 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 16 // Number of NeoPixels
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
boolean oldState = HIGH;
int mode = 0; // Currently-active animation mode, 0-9
pinMode(BUTTON_PIN, INPUT_PULLUP);
strip.begin(); // Initialize NeoPixel strip object (REQUIRED)
strip.show(); // Initialize all pixels to 'off'
// Get current button state.
boolean newState = digitalRead(BUTTON_PIN);
// Check if state changed from high to low (button press).
if((newState == LOW) && (oldState == HIGH)) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if(newState == LOW) { // Yes, still low
if(++mode > 8) mode = 0; // Advance to next mode, wrap around after #8
switch(mode) { // Start the new animation...
case 0:
colorWipe(strip.Color( 0, 0, 0), 50); // Black/off
case 1:
colorWipe(strip.Color(255, 0, 0), 50); // Red
case 2:
colorWipe(strip.Color( 0, 255, 0), 50); // Green
case 3:
colorWipe(strip.Color( 0, 0, 255), 50); // Blue
case 4:
theaterChase(strip.Color(127, 127, 127), 50); // White
case 5:
theaterChase(strip.Color(127, 0, 0), 50); // Red
case 6:
theaterChase(strip.Color( 0, 0, 127), 50); // Blue
case 7:
rainbow(10);
case 8:
theaterChaseRainbow(50);
// Set the last-read button state to the old state.
oldState = newState;
And.......
Sorry again brackets. I mess up again.
Mmmmm. No need to post entire sketch at this point. Take one simple effect and try to convert it.
However, now your main sketch will need to keep a variable to indicate which effect is supposed to be running...
I used states for that, like:
void displayUpdate() {
  static unsigned long updateMillis;
  // 20 Hz display frame rate
  nowMillis = millis();
  if (nowMillis - updateMillis >= 50)
    switch (effectState) {
      case NONE :
        noEffect();
      case BIKINI :
        pinkAndPurplePolkaDottedBikini();
      case RGB_STRIPE :
        shiftRGBStripe(1);
    FastLED.show();
    updateMillis = nowMillis;
I did couple posts above. But now I can't. Don't know why.
    delay(20);
        case 0:
        case 1:
        case 2:
So this is a where button is operate.
You will have to decouple the button code and the display code. They can not be intertwined like that. Your main loop should look like:
  readButton();
  displayUpdate();
I'm trying do this correctly. Sorry. But on phone is complicated a bit.
So back what I would like to do.
That part of code above I'll try to join with this ..........
#define DATA_PIN    3
//#define CLK_PIN   4
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
#define NUM_LEDS    64
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          96
#define FRAMES_PER_SECOND  120
  delay(3000); // 3 second delay for recovery
  // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  // send the 'leds' array out to the actual LED strip
  FastLED.show();
  // insert a delay to keep the framerate modest
  FastLED.delay(1000/FRAMES_PER_SECOND);
  // do some periodic updates
  EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
  EVERY_N_SECONDS( 10 ) { nextPattern(); } // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
I suggest you post later from a computer. Your posts are getting truncated, cut off...
But this is original code from NeoPixel examples.
So?
Ok. Sorry.
It's okay for now. Nothing you posted will work, anyway...
Ok . Maybe tomorrow. Thanks anyway aarg.
Both codes works but little bit different like i would.
#include <FastLED.h>
FASTLED_USING_NAMESPACE
// FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN    3
//#define CLK_PIN   4
#define NUM_LEDS    64
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  FastLED.show();
  FastLED.delay(1000 / FRAMES_PER_SECOND);
    gHue++;  // slowly cycle the "base color" through the rainbow
    nextPattern();  // change patterns periodically
void nextPattern()
void rainbow()
  // FastLED's built-in rainbow generator
  fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
  // built-in FastLED rainbow, plus some random sparkly glitter
  rainbow();
  addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
  if ( random8() < chanceOfGlitter) {
    leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
  // random colored speckles that blink in and fade smoothly
  fadeToBlackBy( leds, NUM_LEDS, 10);
  int pos = random16(NUM_LEDS);
  leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, 20);
  int pos = beatsin16( 13, 0, NUM_LEDS - 1 );
  leds[pos] += CHSV( gHue, 255, 192);
void bpm()
  // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
  uint8_t BeatsPerMinute = 62;
  CRGBPalette16 palette = PartyColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
  for ( int i = 0; i < NUM_LEDS; i++) { //9948
    leds[i] = ColorFromPalette(palette, gHue + (i * 2), beat - gHue + (i * 10));
void juggle() {
  // eight colored dots, weaving in and out of sync with each other
  byte dothue = 0;
  for ( int i = 0; i < 8; i++) {
    leds[beatsin16( i + 7, 0, NUM_LEDS - 1 )] |= CHSV(dothue, 200, 255);
    dothue += 32;
Hi aarg. This is the code I was thinking to adapt to button.
First of all, is it tested?
Yes. It works perfectly. All animations change every couple of seconds. So if I think I understant this .In loop I will put milis which you sugest me yesterday.
      case NONE :
        noEffect();
      case BIKINI :
      case RGB_STRIPE :
        shiftRGBStripe(1);
    FastLED.show();
than i will define button on beginnig of the sketch . And should working??
