Push button turning on a led for certain time
I have wasted multiple days to try and come up with a code that when the button is pressed it turns on a led for 300ms and when the button is released do nothing plz help
Hello grisbar
Welcome to the worldbest Arduino forum ever.
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" and schematic to see how we can help.
This is I think the closest I been to what I want to achieve but it doesn't work
int ledState = LOW;
unsigned long previousMillis = 0;  //will store last time LED was blinked
const long period = 500;         // period at which to blink in ms
  pinMode(13, OUTPUT);
  pinMode(3,INPUT_PULLUP);
  int sensorVal = digitalRead(3);
 unsigned long currentMillis = millis(); // store the current time
if (sensorVal == LOW){
  if (currentMillis - previousMillis >= period) { // check if 1000ms passed
   previousMillis = currentMillis;   // save the last time you blinked the LED
digitalWrite(13,HIGH);
ledState = LOW;
Hello grisbar
Consider these mods of your sketch:
constexpr uint8_t SensorPin {3};
constexpr uint8_t LedPin {13};
  pinMode(LedPin, OUTPUT);
  pinMode(SensorPin, INPUT_PULLUP);
  int sensorVal = digitalRead(SensorPin);
    digitalWrite(LedPin, HIGH);
  if (currentMillis - previousMillis >= period && digitalRead(LedPin) == HIGH)
    digitalWrite(LedPin, LOW);
Thanks for the rapid response
But I want the time the led is on to start as soon as I press down the button
This does...
// https://forum.arduino.cc/t/push-button-turning-on-a-led-for-certain-time/1147387
// https://wokwi.com/projects/370088234566127617
#define buttonPin 2
#define ledPin 3
bool ledState;
unsigned long ledOnMillis;
unsigned long ledOffMillis;
unsigned long durationMillis = 500;
  pinMode (ledPin, OUTPUT);
  pinMode (buttonPin, INPUT_PULLUP);
  digitalWrite(ledPin, LOW);
  if (!digitalRead(buttonPin)) { // test button
    ledOnMillis = millis();
    digitalWrite(ledPin, HIGH);  // LED ON
    ledState = 1; // set LED flag
    delay(150); // debounce the button press
    Serial.print("TIME ON  ");
    Serial.println(ledOnMillis);
  if ((millis() - ledOnMillis > durationMillis) && ledState) { // difference between button to now
    digitalWrite(ledPin, LOW); // LED OFF
    ledOffMillis = millis();
    ledState = 0; // clear LED flag
    Serial.print("TIME OFF ");
    Serial.println(ledOffMillis);
    Serial.print("DURATION ");
    Serial.println(ledOffMillis - ledOnMillis); // show duration
Remove the Serial.print() statements to make the timing more accurate.
Hello grisbar
Be more specific about what the task of the sketch is.
Well I asked a friend for any advice and he said to just ask the chat gpt bot and I did so . It made mistakes 5 times but at the end I told him to use the edge state Library and it sent me what I wanted
#include <Arduino.h>
const int buttonPin = 3;   // The pin where the push button is connected
const int ledPin = 4;      // The pin where the LED is connected
int buttonState = 0;       // Variable to store the state of the button
int lastButtonState = 0;   // Variable to store the previous state of the button
bool ledOn = false;        // Flag to indicate whether the LED is currently on
unsigned long previousMillis = 0;   // Variable to store the previous time
  pinMode(buttonPin, INPUT_PULLUP);  // Set the button pin as INPUT
with internal pull-up resistor
  pinMode(ledPin, OUTPUT);            // Set the LED pin as OUTPUT
  // Read the state of the button
  buttonState = digitalRead(buttonPin);
  // Check for button press event
  if (buttonState != lastButtonState && buttonState == LOW) {
    // Button is pressed, toggle the LED and set the previous time
    ledOn = !ledOn;
    digitalWrite(ledPin, ledOn ? HIGH : LOW);
    previousMillis = millis();
  // Check if the LED is on and if 300 milliseconds have passed
  if (ledOn && (millis() - previousMillis >= 300)) {
    // Turn off the LED
    ledOn = false;
  // Store the current button state for the next iteration
  lastButtonState = buttonState;
