push buttonsss
int b1 = 9;
int b2 = 8;
int
//button status
boolean bu1 =0;
boolean bu2 =0;
//Status of whether or not a button has been pressed
int hold = 0;
  //allows you to see on a computer who buzzed in first
 //Lockout Status LED pin with is statndard on the Arduino Board(s)
  pinMode(13, OUTPUT);
  //Button inputs defined
  pinMode(b1, INPUT);
  pinMode(b2, INPUT);
  //The delay allows time for the voltage to stabilize (exp. because the electronics are not removed from the buttons!)
  //Read to see if a button is pushed
  if(hold == 0){
    bu1 = digitalRead(b1);
    bu2 = digitalRead(b2);
    //player 1
    if(digitalRead(b1)==HIGH||digitalRead(b2)==LOW)
      hold=1; //lockout the other users
      Serial.println("Player 1");
    //player 2
    if(digitalRead(b2)==HIGH||digitalRead(b1)==LOW){
      Serial.println("Player 2");
  else{
    digitalWrite(13, HIGH);   // set the LED on to indicate that the other users are locked out
void time(){
 delay(15000);
[font=Verdana][/font]
Sir i need a little help..i am a beginner here,,i dont think this gonna work..:smiley: please help for better code..
i want to output the first button who pressed first. thanks
Not a great attitude to approach software development.
Make sure both switches are on the same port and read the whole port.
digitalRead is relatively slow.
You give up without even trying ? Make some experiments with your code, post your results and then ask questions. :slight_smile:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;     // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
int hold=0;
// initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
if(hold==0)
if(buttonState1||buttonState2){
delay(5000);
  if (buttonState == HIGH) {
    // turn LED on:
	hold=1;
	digitalWrite(ledPin1, HIGH);
if(buttonState2==HIGH){
	hold=1;
	digitalWrite(ledPin2, HIGH);
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
well thanks sir..i have sought a new code..i just need it yout reply...
yinyangXD:
How can you check which person pressed their button first with only a single button
How?
delay(5000);
You're checking three different buttonState variables, but you've only declared and read 1; That's not going to work.
The last code you posted doesn't even compile. Please take at least the effort to post compilable code. Thank you.
AWOL:
Not compared to me it isn't.
Not compared to me it isn’t.
It’s all about perspective.
