Push/Rotation Mechanism
Given an object, say a book, I would like a simple machine that can push one of its corners with certain force to have an effect of rotating the book.
After researching, seems like a linear actuator or a rack and pinion servo motor can be used for pushing.
I would love to hear your suggestions on achieving this!
Thank you!
Based on your specifications, either will work. Go for it!
Paul
Pushing a book normally translates it too. Perhaps you want only rotation?
Thank you very much for your replies!
@MarkT, say I would like only rotation - how would you go about this?
ronny3050:
If you want only rotation, then you must supply a pivot point to control the other movement.
Paul
maybe a stepper motor to rotate the gear that this book is sitting on?
