pushbutton counter stops at 11
Pls Help!
previously my pushbutton counter counts up to 99, however, when I reload the program the counter stops at 11 and it never continue. When I checked the code, nothing has change actually. I just wander why this happened? thanks
Let's see the program and the circuit.
that part of my code:
incButton=digitalRead(incPin);
decButton=digitalRead(decPin);
if ( incButton!=incLastButtonState)
if (incButton==HIGH)
if (Score!=99)
{Score++;
Here is part of my answer
The problem is somewhere in your code or wiring.
Please post the whole program or a smaller but complete program that exhibits the problem.
Full code please. And post it between code tags
[code]your code here [/code]
will result in
your code here
             if (Score!=99)
             {Score++;
I reloaded working program before. BUt, is it possible that there's something wrong with my wiring?
And in the next line you have something that states if (score > 11) score = 11';
Complete program please (again) or a small program that exhibits the problem. If it can count to 11 without problems, I can't see that this is a wiring problem.
thanks a lot guys..... now I got the answer. it was from my score=10. It should be score-10.
More power to arduino family and admin.
A perfect example of why you should post a complete program.
