I'm new to Arduino, and I'm trying to implement a debouncing code function that will be used in a pushbutton circuit I have that is using a 7 segment display to count every pushbutton press from 0 to 9.
The problem I'm having is when I run the code, my display is stuck on 0, and won't recognize any presses. Any help would be appreciated!!
I'm using the Uno R3 Arduino
const int a=2;
const int b=3;
const int c=4;
const int d=5;
const int e=6;
const int f=7;
const int g=8;
const int buttonPin = 9;
int validButtonPress = 0;
int count = 0;
int buttonPress = 0;
int buttonState = 0;
int lastButtonState = 0;
long lastDebounceTime = 0;
long debounceDelay = 50;
//Designating input/output pins
pinMode(buttonPin, INPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
if (readButton(buttonPin) == 1)
buttonState = digitalRead(buttonPin);
//Checking for a button press
if (validButtonPress == 1)
if (buttonState != lastButtonState)
//counting function
if (buttonState == 1)
count++;
lastButtonState = buttonState;
//Switch case for incrementing LED counter
switch(count)
case 0:
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, HIGH);
case 1:
digitalWrite(a, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
case 2:
digitalWrite(c, HIGH);
digitalWrite(g, LOW);
case 3:
case 4:
case 5:
digitalWrite(b, HIGH);
case 6:
case 7:
case 8:
case 9:
default: count=0; break;
//Attempted debouncing code
int readButton(int buttonPin)
int reading = digitalRead(buttonPin);
if (reading != lastButtonState)
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay)
if (reading != buttonState)
buttonState = reading;
if (buttonState == HIGH)
validButtonPress = 1;
lastButtonState = reading;
return validButtonPress;
