The following code run 2 stepper motors, when I tested, two problems happened,
- Push button didn't work
- 2 stepper motors only ran one direction.
Could you check the code for me, thanks!!!
#define EN 8
#define X_DIR 3
#define X_STP 2
#define Y_DIR 5
#define Y_STP 4
int pushbuttonpin = 7;
int val = 0;
void step(boolean dir, byte dirPin, byte stepperPin, int steps)
val = digitalRead(pushbuttonpin); //Read push button switch pin status
if (val == HIGH)
digitalWrite(dirPin, dir);
delay(50);
for (int i = 0; i < steps; i++) {
digitalWrite(stepperPin, HIGH);
delayMicroseconds(800);
digitalWrite(stepperPin, LOW);
pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
pinMode(Y_DIR, OUTPUT); pinMode(Y_STP, OUTPUT);
pinMode(EN, OUTPUT);
digitalWrite(EN, LOW);
void loop(){
step(false, X_DIR, X_STP, 2000);
step(false, Y_DIR, Y_STP, 2000);
step(true, X_DIR, X_STP, 2000);
step(true, Y_DIR, Y_STP, 2000);
