pushbutton servos
so i was hoping that someone could help me with a bit of code. the project i am working on requires me to have 2 servos, that when a button is pushed, go in opposite directions. this is my code so far. however i cant seem to get another servo to work with it, any help would be greatly appreciated
  State change detection (edge detection)
 Often, you don't need to know the state of a digital input all the time,
 but you just need to know when the input changes from one state to another.
 For example, you want to know when a button goes from OFF to ON.  This is called
 state change detection, or edge detection.
 This example shows how to use button state change to perform an action.
 The circuit:
 * Momentary pushbutton attached to digital pin 2 from +5V
 * 10K resistor attached to digital pin 2 from ground
 * Servo signal wire attached to digital pin 9
 * Servo power wire connected to 5v
 * Servo ground wire connected to ground
 Based off the public domain "State Change Detection" example provided with the
 Arduino software. Code edited 8-14-2011 by Will Lyon (SXRguyinMA) to remove
 the LED and add in a servo.
 For the purpose of
 "Integrating Electronics Into Your Next Proect" series of articles on TBCS
 www.thebestcasescenario.com
// Include the servo library
#include <VarSpeedServo.h>
// Create a servo object to control a servo
VarSpeedServo myservo;
// this constant won't change:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  // attach the Servo to pin 9
  myservo.attach(9);
  // make sure the servo starts off with the door closed
  myservo.slowmove(180, 0);
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // read the pushbutton input pin:
  int buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
    else {
    // save the current state as the last state,
    //for next time through the loop
    lastButtonState = buttonState;
  // moves the servo every other button push by
  // checking the modulo of the button push counter.
  // the modulo function gives you the remainder of
  // the division of two numbers:
  if (buttonPushCounter % 2 == 0) {
   myservo.slowmove(0, 180);
   myservo.slowmove(180, 180);
You've only declared one servo.
You need to declare another one on a different pin.
Moving two servos in opposite directions using the Servo library is not a problem. Moving two servos in opposite directions using the VarSpeedServo library is.
You can emulate what VarSpeedServo is doing by using small intervals between small steps.
I fail to see how the else block is accomplishing anything. Generally, when you struggle to figure out what to put in the else block, it's a sure sign that no else block is needed.
And, of course, what AWOL said.
i agree with you that the var speed servo probably wasn't the best idea. but it'd be a shame to waste the code if i could easily fix it. i tried adding a second servo to the code last night, and it didnt work.
this was my Finished code when i was done
VarSpeedServo myservo2;
  myservo.attach(9);
 myservo2.attach(11);
  myservo2.slowmove(0, 180);
    else {
myservo2.slowmove(180, 0);
 myservo2.slowmove(180, 180);
if it doesnt look like this will work for me, i have no problem scrapping it, i just appreciate the help
and it didnt work.
The code does something. You expect it to do something. "It didn't work" says that the two somethings are not the same thing, but doesn't say what either one is.
How can you have #2 without having #1? A pet peeve of mine...
I'd noticed that.
does it have to be labeled 1? in my head i just considered it as 1 >.>
No, but I like names that mean something. If adding a 2 to the end of a name means something, and adding a 3 for the next one, then adding a 1 for the first one makes sense, too.
Of course, names like leftServo and rightServo might make sense, too, and make it more difficult to modify the wrong instance.
ahh i gotcha, well other then that, any ideas why the second one wont work, too me the code seems like it should run the second servo, but i get nothing from it when i push the button
Try swapping the order of the statements. Drive the other servo first. Does that make a difference?
alright, i unplugged the servo 1 from pin 9 and plugged it into pin 11 and i got nothing. i also went into the code and commented out anything that had to do with servo 1. and i still got no response from servo 2 when the button was pressed
Simple servo button test code you can try.
//zoomkat servo button toggle test 4-28-2012
#include <Servo.h>
int button = 5; //button pin, connect to ground to move servo
int press = 0;
Servo servo;
boolean toggle = true;
  pinMode(button, INPUT); //arduino monitor pin state
  servo.attach(7); //pin for servo control signal
  digitalWrite(5, HIGH); //enable pullups to make pin high
  press = digitalRead(button);
  if (press == LOW)
    if(toggle)
      servo.write(160);
      toggle = !toggle;
      servo.write(20);
      toggle = !toggle;
  delay(500);  //delay for debounce
your code works great thanks!
i tried adding a second servo to it,
#include <Servo.h>
int button = 2; //button pin, connect to ground to move servo
int press = 0;
Servo servo1;
Servo servo2;
  servo1.attach(9); //pin for servo control signal
  servo2.attach(10); //pin for servo control signal
  digitalWrite(2, HIGH); //enable pullups to make pin high
  if (press == LOW)
    if(toggle)
      servo1.write(0);
      toggle = !toggle;
       servo2.write(180);
      toggle = !toggle;
      servo1.write(180);
      toggle = !toggle;
       servo2.write(0);
      toggle = !toggle;
it didnt seem to work.... i think there's something im not getting
openroad12:
#include <Servo.h>
int press = 0;
Servo servo1;
Servo servo2;
  if (press == LOW)
    if(toggle)
      servo1.write(0);
      toggle = !toggle;
       servo2.write(180);
      toggle = !toggle;
      servo1.write(180);
      toggle = !toggle;
       servo2.write(0);
      toggle = !toggle;
I suspect you need to use separate 'toggle' variables for the two servos, perhaps toggle1 and toggle2?
Lefty
like so?
#include <Servo.h>
int press = 0;
Servo servo1;
Servo servo2;
boolean toggle1 = true;
boolean toggle2 = true;
  if (press == LOW)
    if(toggle1)
    if(toggle2)
      servo1.write(0);
      toggle1 = !toggle1;
       servo2.write(180);
      toggle2 = !toggle2;
      servo1.write(180);
      toggle1 = !toggle1;
       servo2.write(0);
      toggle2 = !toggle2;
If two servos need to go on opposite directions, I'd try addubg the second servo like below. I don't have a servo connected to test with currently.
#include <Servo.h>
int press = 0;
Servo servo;
Servo servo1;
  servo1.attach(8); //pin for servo control signal
  if (press == LOW)
    if(toggle)
      servo.write(160);
      servo1.write(20);
      toggle = !toggle;
      servo.write(20);
      servo1.write(160);
      toggle = !toggle;
this is perfect!! thank you so much!
