PUSHBUTTON+SWITCH CASE
I am developing a project for my college.
PROJECT OUTLINE:
There are 3 sensors (Temp., Accelerometer & Humidity) will read the respective parameters continuously. in between if I press ‘PushButton1’ for 2 seconds the Arduino must enter into programming mode.
The programming mode has 6 Switch cases. Each case gets selected one after one on the even of ‘PushButton1’ gets pressed for short time.
Also if i press ‘PushButton1’ again for 2 seconds in Programming mode the Arduino should come out of the programming mode.
PROBLEM:
In my current sketch I have to press ‘PushButton1’ for 2 seconds in Programming Mode for 2 seconds to change the case. Also I don’t understand how to get out of the Switch Case loop.
The sketch is attached with this topic.
PRESS_BUTTON_8.ino (1.32 KB)
swa8788:
PROJECT OUTLINE:
There are 3 sensors (Temp., Accelerometer & Humidity) will read the respective parameters continuously. in between if I press 'PushButton1' for 2 seconds the Arduino must enter into programming mode.
The programming mode has 6 Switch cases. Each case gets selected one after one on the even of 'PushButton1' gets pressed for short time.
Also if i press 'PushButton1' again for 2 seconds in Programming mode the Arduino should come out of the programming mode.
PROBLEM:
In my current sketch I have to press 'PushButton1' for 2 seconds in Programming Mode for 2 seconds to change the case. Also I don’t understand how to get out of the Switch Case loop.
const int btn = 2;
const int ledPin = 13;
int selector = 0;
boolean volatile wait = false;
const unsigned long event=2000;
unsigned long a=0;
unsigned long b=0;
unsigned long c=0;
pinMode(ledPin, OUTPUT);
pinMode(btn, INPUT);
attachInterrupt(digitalPinToInterrupt(btn),decoder,CHANGE);
while(wait) { }
if (digitalRead(btn) == LOW) {
a = millis();
b = millis();
c=b-a;
Serial.println(c);
if (c>=event)
doSwitchStatement();
selector++;
if (selector >6)
selector = 0;
wait = true;
interrupts();
void decoder()
noInterrupts();
wait = false;
void doSwitchStatement()
switch(selector)
case 0:
Serial.println("Case 0");
case 1:
Serial.println("Case 1");
case 2:
Serial.println("Case 2");
case 3:
Serial.println("Case 3");
case 4:
Serial.println("Case 4");
case 5:
Serial.println("Case 5");
case 6:
Serial.println("Case 6");
You’re not getting stuck in the case statement. You’re getting stuck here....
 while(wait) {  }
That just loops forever if wait == true
That gets set the first time through your loop function.
Why are you using interrupts for a push-button?
Does it have hardware debounce?
Please remember to use code tags when posting code
