Take this for a spin and see how it works for you. It should update the LCD twice a second (every 500 milliseconds), I set the update frequency (READ_FREQUENCY_MS) at the top. The faster you let it update the more the screen will flicker, then again slow updates aren't helpful on a 'live' scale so you might need to find a balance.
#include "HX711.h"
#include "KTS_Button.h"
#define READ_FREQUENCY_MS 500
#define DOUT 8
#define CLK 7
#define unitsPin 6 //Units button at pin 6
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int tarePin = 9; //Tare button at pin 9
float tareVal = 0;
float i = 0;
HX711 scale;
float calibration_factor = 360; //calibration factor for 5kg amazon load cell with gain 128 and grams as units
KTS_Button tareButton(tarePin);
KTS_Button unitsButton(unitsPin);
enum Unit {
grams = 0,
ounces,
NUM_UNITS
}; Unit currentUnit = grams;
void cycleUnits() {
currentUnit = currentUnit + 1;
if (currentUnit == NUM_UNITS)
currentUnit = 0;
pinMode(SCK, OUTPUT);
pinMode(tarePin, INPUT_PULLUP);
lcd.begin(16, 2);
scale.begin(DOUT, CLK, 128); //Start communications to HX711 pins and set gain factor 64|128 are options on Channel A
scale.set_scale(calibration_factor); //Required during scale startup, scale factor will be adjusted in main loop for calibration
scale.tare(); //Reset the scale to 0
if (tareButton.read() == SINGLE_PRESS) {
lcd.clear();
lcd.print("Tare");
scale.tare();
if (unitsButton.read() == SINGLE_PRESS) {
cycleUnits();
static uint32_t timeCapture;
if ((millis() - timeCapture) > READ_FREQUENCY_MS) {
timeCapture = millis();
lcd.clear();
lcd.print("Weight: ");
lcd.setCursor(0,1);
switch (currentUnit) {
case grams:
lcd.print(scale.get_units (4), 1);
lcd.print("g");
break;
case ounces:
lcd.print(scale.get_units (4) * 0.03524, 1);
lcd.print("oz");
break;
