Greetings all,
I have used the Neopixel Code Generator to build build some basic animations, but I was curious if anyone could tell me how to modify the code so that the animation sequences can be advanced with a pushbutton trigger, instead of just a round robin loop. Here's the code from the generator:
class Strip
public:
uint8_t effect;
uint8_t effects;
uint16_t effStep;
unsigned long effStart;
Adafruit_NeoPixel strip;
Strip(uint16_t leds, uint8_t pin, uint8_t toteffects, uint16_t striptype) : strip(leds, pin, striptype) {
effect = -1;
effects = toteffects;
Reset();
void Reset(){
effStep = 0;
effect = (effect + 1) % effects;
effStart = millis();
struct Loop
uint8_t currentChild;
uint8_t childs;
bool timeBased;
uint16_t cycles;
uint16_t currentTime;
Loop(uint8_t totchilds, bool timebased, uint16_t tottime) {currentTime=0;currentChild=0;childs=totchilds;timeBased=timebased;cycles=tottime;}
Strip strip_0(14, 8, 14, NEO_GRB + NEO_KHZ800);
struct Loop strip0loop0(4, false, 1);
struct Loop strip0loop00(2, false, 1);
struct Loop strip0loop01(2, false, 1);
//[GLOBAL_VARIABLES]
//Your setup here:
strip_0.strip.begin();
//Your code here:
strips_loop();
void strips_loop() {
if(strip0_loop0() & 0x01)
strip_0.strip.show();
uint8_t strip0_loop0() {
uint8_t ret = 0x00;
switch(strip0loop0.currentChild) {
case 0:
ret = strip0_loop0_eff0();break;
case 1:
ret = strip0_loop0_eff1();break;
case 2:
ret = strip0_loop00();break;
case 3:
ret = strip0_loop01();break;
if(ret & 0x02) {
ret &= 0xfd;
if(strip0loop0.currentChild + 1 >= strip0loop0.childs) {
strip0loop0.currentChild = 0;
if(++strip0loop0.currentTime >= strip0loop0.cycles) {strip0loop0.currentTime = 0; ret |= 0x02;}
else {
strip0loop0.currentChild++;
return ret;
uint8_t strip0_loop0_eff0() {
// Strip ID: 0 - Effect: Fade - LEDS: 14
// Steps: 996 - Delay: 1
// Colors: 2 (255.0.0, 255.130.0)
// Options: duration=996, every=1,
if(millis() - strip_0.effStart < 1 * (strip_0.effStep)) return 0x00;
uint8_t r,g,b;
double e;
e = (strip_0.effStep * 1) / (double)996;
r = ( e ) * 255 + 255 * ( 1.0 - e );
g = ( e ) * 130 + 0 * ( 1.0 - e );
b = ( e ) * 0 + 0 * ( 1.0 - e );
for(uint16_t j=0;j<14;j++) {
if((j % 1) == 0)
strip_0.strip.setPixelColor(j, r, g, b);
strip_0.strip.setPixelColor(j, 0, 0, 0);
if(strip_0.effStep >= 996) {strip_0.Reset(); return 0x03; }
else strip_0.effStep++;
return 0x01;
uint8_t strip0_loop0_eff1() {
// Steps: 990 - Delay: 1
// Colors: 2 (255.130.0, 255.0.0)
// Options: duration=990, every=1,
uint8_t r,g,b;
double e;
e = (strip_0.effStep * 1) / (double)990;
g = ( e ) * 0 + 130 * ( 1.0 - e );
if((j % 1) == 0)
if(strip_0.effStep >= 990) {strip_0.Reset(); return 0x03; }
return 0x01;
uint8_t strip0_loop00() {
uint8_t ret = 0x00;
switch(strip0loop00.currentChild) {
case 0:
ret = strip0_loop00_eff0();break;
case 1:
ret = strip0_loop00_eff1();break;
if(ret & 0x02) {
ret &= 0xfd;
if(strip0loop00.currentChild + 1 >= strip0loop00.childs) {
strip0loop00.currentChild = 0;
if(++strip0loop00.currentTime >= strip0loop00.cycles) {strip0loop00.currentTime = 0; ret |= 0x02;}
else {
strip0loop00.currentChild++;
return ret;
uint8_t strip0_loop00_eff0() {
// Strip ID: 0 - Effect: Move - LEDS: 14
// Steps: 13 - Delay: 50
// Colors: 0 ()
// Options: toLeft=true, rotate=false,
if(millis() - strip_0.effStart < 50 * (strip_0.effStep)) return 0x00;
for(uint16_t j=0;j<13;j++)
strip_0.strip.setPixelColor(j, strip_0.strip.getPixelColor(j+1));
if(strip_0.effStep >= 13) {strip_0.Reset(); return 0x03; }
return 0x01;
uint8_t strip0_loop00_eff1() {
// Steps: 14 - Delay: 50
// Colors: 0 ()
// Options: toLeft=false, rotate=false,
for(uint16_t j=14-1;j>0;j--)
strip_0.strip.setPixelColor(j, strip_0.strip.getPixelColor(j-1));
if(strip_0.effStep >= 14) {strip_0.Reset(); return 0x03; }
return 0x01;
uint8_t strip0_loop01() {
uint8_t ret = 0x00;
switch(strip0loop01.currentChild) {
case 0:
ret = strip0_loop01_eff0();break;
case 1:
ret = strip0_loop01_eff1();break;
if(ret & 0x02) {
ret &= 0xfd;
if(strip0loop01.currentChild + 1 >= strip0loop01.childs) {
strip0loop01.currentChild = 0;
if(++strip0loop01.currentTime >= strip0loop01.cycles) {strip0loop01.currentTime = 0; ret |= 0x02;}
else {
strip0loop01.currentChild++;
return ret;
uint8_t strip0_loop01_eff0() {
// Strip ID: 0 - Effect: Blink - LEDS: 14
// Steps: 115 - Delay: 10
// Options: timeBegin=500, timeToOn=50, timeOn=50, timeToOff=50, timeOver=500, every=2,
if(millis() - strip_0.effStart < 10 * (strip_0.effStep)) return 0x00;
uint8_t e,r,g,b;
if(strip_0.effStep < 50) {
strip_0.strip.setPixelColor(j, 255, 130, 0);
else if(strip_0.effStep < 55) {
e = (strip_0.effStep * 10) - 500;
r = 255 * ( e / 50 ) + 255 * ( 1.0 - e / 50 );
g = 0 * ( e / 50 ) + 130 * ( 1.0 - e / 50 );
b = 0 * ( e / 50 ) + 0 * ( 1.0 - e / 50 );
if((j%2)==0) strip_0.strip.setPixelColor(j, r, g, b);
else strip_0.strip.setPixelColor(j, 255, 130, 0);
else if(strip_0.effStep < 60) {
if((j%2)==0) strip_0.strip.setPixelColor(j, 255, 0, 0);
else if(strip_0.effStep < 65) {
e = (strip_0.effStep * 10) - 600;
g = 130 * ( e / 50 ) + 0 * ( 1.0 - e / 50 );
else {
if(strip_0.effStep >= 115) {strip_0.Reset(); return 0x03; }
return 0x01;
uint8_t strip0_loop01_eff1() {
uint8_t e,r,g,b;
else strip_0.strip.setPixelColor(j, 255, 0, 0);
if((j%2)==0) strip_0.strip.setPixelColor(j, 255, 130, 0);
else {
return 0x01;
Can anyone assist?
