Pushbutton wont work in my project?
Hello, I am using a servo to turn a light switch on and off with the help of a IR Remote, but i tired to add a pushbutton as an OR option so im not stuck using just the IR Remote incase I lose it. The code compiles but does not work. I can control with the IR Remote but not the buttons.
Here is the code:
#include <IRremote.h> //must copy IRremote library to arduino libraries
#include <Servo.h>
#define on 0xffa25d //clockwise rotation button
#define off 0xff629d //counter clockwise rotation button
int RECV_PIN = 2; //IR receiver pin
Servo servo;
int val; //rotation angle
bool cwRotation, ccwRotation; //the states of rotation
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
servo.attach(9); //servo pin
pinMode(4, INPUT);
pinMode(5, INPUT);
if (irrecv.decode(&results)) {
String s = String(results.value, HEX);
if(s != "ffffffff"){
Serial.println(s);
irrecv.resume(); // Receive the next value
if (results.value == on || digitalRead(4) == LOW)
cwRotation = !cwRotation; //toggle the rotation value
ccwRotation = false; //no rotation in this direction
if (results.value == off || digitalRead(5) == LOW)
ccwRotation = !ccwRotation; //toggle the rotation value
if (cwRotation && (val != 135)) {
val++; //for colockwise button
if (ccwRotation && (val != 0)) {
val--; //for counter colockwise button
servo.write(val);
delay(2); //General speed
Do you have pull-up resistors on those inputs? If not, try INPUT_PULLUP as the mode.
Do you have a wiring diagram of your setup?
Sadly I don't have a wiring diagram. It a regular resistor. I just tried what you said and it gave me the same result. I will make a diagram now
Actually, I think I see the problem. This is where posting code with code tags helps clarify things.
You've got your button checks embedded within the logic for receiving an IR message.
If you don't receive an IR message, you don't check the buttons.
how can I fix that? I'm new to Arduino. I can do basic things but have never tried anything like this lol
Here is the wiring diagram
x3xplosiiv3x_:
Have a look at the code here. I can't vouch for your logic and it appears there may be some "gotchyas" in there, such as pressing a button twice may have unintended consequences because you just '!' a variable upon a button press. I didn't devote a lot of time to digging into it. So keep that in mind. But this basically separates out the IR and button press functions.
#include <Servo.h>
#define ON_BUTTON               4   //pin 4 is 'on' input
#define OFF_BUTTON              5   //pin 5 is 'off' input
#define MOTOR_INTERVAL          2   //mS
#define BUTTON_CHECK_INTERVAL   20  //mS
Servo servo;
  pinMode(ON_BUTTON, INPUT);
  pinMode(OFF_BUTTON, INPUT);
IR_Receive()
        if(s != "ffffffff")
            Serial.println(s);
        }//if
        if( results.value == on )
        }//if
        if (results.value == off)
        }//if
    }//if
}//IR_Receive
void Check_Buttons()
    static unsigned long
        buttoncheckTime = millis() + BUTTON_CHECK_INTERVAL;
    if( millis() < buttoncheckTime )
        return;
    if( digitalRead(ON_BUTTON) == LOW )
    }//if
    if( digitalRead(OFF_BUTTON) == LOW)
    }//if
}//Check_Buttons
void ProcessMotor( void )
        motorInterval = millis() + MOTOR_INTERVAL;
    if( millis() < motorInterval )
        return;
    servo.write(val);
}//ProcessMotor
    IR_Receive();
    CheckButtons();
    ProcessMotor();
}//loop
ok, thank you!
