im trying to make a Morse code translator. I need to use a button to start it. It works good with out the button but when i try to hook the there is now many problems with the code. The code bellow is the code with button
//Define the LED Pin
#define PIN_OUT 9
//Define unit length in ms
#define UNIT_LENGTH 250
//Build a struct with the morse code mapping
static const struct {const char letter, *code;} MorseMap[] =
{ 'A', ".-" },
{ 'B', "-..." },
{ 'C', "-.-." },
{ 'D', "-.." },
{ 'E', "." },
{ 'F', "..-." },
{ 'G', "--." },
{ 'H', "...." },
{ 'I', ".." },
{ 'J', ".---" },
{ 'K', ".-.-" },
{ 'L', ".-.." },
{ 'M', "--" },
{ 'N', "-." },
{ 'O', "---" },
{ 'P', ".--." },
{ 'Q', "--.-" },
{ 'R', ".-." },
{ 'S', "..." },
{ 'T', "-" },
{ 'U', "..-" },
{ 'V', "...-" },
{ 'W', ".--" },
{ 'X', "-..-" },
{ 'Y', "-.--" },
{ 'Z', "--.." },
{ ' ', " " }, //Gap between word, seven units
{ '1', ".----" },
{ '2', "..---" },
{ '3', "...--" },
{ '4', "....-" },
{ '5', "....." },
{ '6', "-...." },
{ '7', "--..." },
{ '8', "---.." },
{ '9', "----." },
{ '0', "-----" },
const int buttonPin = 2;
int buttonState = 0;
const int ledPin = A0;
pinMode( PIN_OUT, OUTPUT );
digitalWrite( PIN_OUT, LOW );
pinMode(buttonPin, INPUT);
pinMode(A0, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
String morseWord = encode( "1234 " );
for(int i=0; i<=morseWord.length(); i++)
switch( morseWord[i] )
case '.': //dit
digitalWrite( PIN_OUT, HIGH );
delay( UNIT_LENGTH );
case '-': //dah
delay( UNIT_LENGTH*3 );
case ' ': //gap
String encode(const char *string)
size_t i, j;
String morseWord = "";
for( i = 0; string[i]; ++i )
for( j = 0; j < sizeof MorseMap / sizeof *MorseMap; ++j )
if( toupper(string[i]) == MorseMap[j].letter )
morseWord += MorseMap[j].code;
morseWord += " "; //Add tailing space to seperate the chars
return morseWord;
String decode(String morse)
String msg = "";
int lastPos = 0;
int pos = morse.indexOf(' ');
while( lastPos <= morse.lastIndexOf(' ') )
for( int i = 0; i < sizeof MorseMap / sizeof *MorseMap; ++i )
if( morse.substring(lastPos, pos) == MorseMap[i].code )
msg += MorseMap[i].letter;
lastPos = pos+1;
pos = morse.indexOf(' ', lastPos);
// Handle white-spaces between words (7 spaces)
while( morse[lastPos] == ' ' && morse[pos+1] == ' ' )
pos ++;
return msg;
else {
// turn LED off:
digitalWrite(ledPin, LOW);
