Pushbutton
Im trying to start and stop a program. It definitely start when i press the button but as i soon press the button again, it wont work. it continuously on the loop.
here is the code:
int run;
int buttonPin;
int stepPin = 11;
int dirPin = 10;
int enPin = 9;
int LimitSwitch_LEFT_Pin = 3;
int LimitSwitch_RIGHT_Pin = 5;
boolean bIsRaining = false;
String strRaining;
int nRainIn = A1;
int nRainDigitalIn = 2;
int nRainVal;
run = 0;
buttonPin = 4;
pinMode(buttonPin, INPUT_PULLUP);
pinMode(2, INPUT);
pinMode(LimitSwitch_LEFT_Pin , INPUT);
pinMode(LimitSwitch_RIGHT_Pin , INPUT);
pinMode(stepPin, OUTPUT); // Sets the two pins as Outputs
pinMode(dirPin, OUTPUT);
pinMode(enPin, OUTPUT);
digitalWrite(enPin, LOW); // Set Dir to Home switch
digitalWrite(dirPin, HIGH); // Enables the motor to move in a particular direction
digitalWrite(buttonPin, HIGH);
if (digitalRead(4) == LOW)
{ if (run == 0)
run = 255;
run = 0;
if (run > 0)
nRainVal = analogRead(nRainIn);
bIsRaining = !(digitalRead(nRainDigitalIn));
if (bIsRaining) {
strRaining = "YES";
digitalWrite(3, LOW);
digitalWrite(5, HIGH);
digitalWrite(11, HIGH);
digitalWrite(enPin, LOW); //habilita em low invertida
digitalWrite(dirPin, HIGH); // low CW / high CCW
else {
strRaining = "NO"; //habilita em low invertida
digitalWrite(dirPin, LOW);
digitalWrite(5, LOW);
digitalWrite(3, HIGH);
int leftSw = digitalRead( LimitSwitch_LEFT_Pin);
int rightSw = digitalRead( LimitSwitch_RIGHT_Pin);
if ( (leftSw == HIGH && (digitalRead(dirPin) == HIGH)) ||
(rightSw == HIGH && (digitalRead(dirPin) == LOW)) ) {
motorStep(1);
else if ( leftSw == LOW && (digitalRead(dirPin) == HIGH) ) {
delay(2000);
else if ( rightSw == LOW && (digitalRead(dirPin) == LOW ) ) {
delay(2000);
void motorStep( int MAX) {
for (int x = 0; x < MAX; x++) {
digitalWrite(stepPin, HIGH);
delayMicroseconds(500);
digitalWrite(stepPin, LOW);
Please follow the rules.
Always show us your ‘current’ complete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code]Paste sketch here. [/code]
Did you read the stickies at the top of the forums?
https://forum.arduino.cc/index.php?topic=149014.0
Edit
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Give links to components.
Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
buttonPin = 4; // a local variable
digitalWrite(buttonPin, HIGH); // why?
Then buttonPin is never heard from again.
Stick with using variable names throughout your sketch.
For switches use state change detection.
Don’t use delay() as the sketch progress stops for that amount of time.
See Robin2’s blink without delay (doing multiple things at once) discussion.
