Pushing data from Xbee to Arduino to ESP8266
Hello, guys! Since i got my ESP8266-Arduino running, what i need to do now is to send the incoming data from xbee to the internet via this wifi module. can someone help me? I tried reading the data from the xbee and put it as input to be sent by ESP8266. Here’s my code:
#include <SoftwareSerial.h>
String ssid = “Qtpi”;
String password = “chocomallowpie”;
SoftwareSerial esp(10, 11);// RX, TX
SoftwareSerial XBee(17, 16);//RX, TX
String data;
String server = “34.211.192.31”; // www.example.com
String uri = “test.php”;// our example is /esppost.php
String sens1 , sens2;
String datasens1;
XBee.begin(9600);
esp.begin(9600);
reset();
connectWifi();
//reset the esp8266 module
void reset() {
esp.println(“AT+RST”);
if (esp.find(“OK”) ) Serial.println(“Module Reset”);
//connect to your wifi network
void connectWifi() {
String cmd = “AT+CWJAP=”" + ssid + “”,"" + password + “”";
esp.println(cmd);
delay(4000);
if (esp.find(“OK”)) {
Serial.println(“Connected!”);
else {
connectWifi();
Serial.println(“Cannot connect to wifi”);
void loop () {
// convert the bit data to string form
if (XBee.available()) {
Serial.write(XBee.read());
datasens1 = XBee.read();
sens1 = datasens1 ;
data = “waterlvl=” + sens1;// data sent must be under this form //name1=value1&name2=value2.
httppost();
void httppost () {
esp.println(“AT+CIPSTART=“TCP”,”" + server + “”,80");//start a TCP connection.
if ( esp.find(“OK”)) {
Serial.println(“TCP connection ready”);
} delay(1000);
String postRequest =
“POST " + uri + " HTTP/1.0\r\n” +
"Host: " + server + “\r\n” +
“Accept: " + “/” + "\r\n” +
"Content-Length: " + data.length() + “\r\n” +
“Content-Type: application/x-www-form-urlencoded\r\n” +
“\r\n” + data;
String sendCmd = “AT+CIPSEND=”;//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(postRequest.length() );
if (esp.find(">")) {
Serial.println(“Sending…”); esp.print(postRequest);
if ( esp.find(“SEND OK”)) {
Serial.println(“Packet sent”);
while (esp.available()) {
String sensdata1 = esp.readString();
Serial.println(sensdata1);
// close the connection
esp.println(“AT+CIPCLOSE”);
And what happens when you run the code? Does the Arduino receive the data? Does the ESP connect?
What is the role of the Arduino? And which Arduino?
groundFungus:
this is the result:
Sending…
Packet sent
+IPD,485:HTTP/1.1 400 Bad Request
Date: Tue, 18 Jul 2017 16:42:08 GMT
Server: Apache/2.4.7 (Ubuntu)
Content-Length: 304
Connection: close
Content-Type: text/html; charset=iso-8859-1
400 Bad Request
Bad Request
Your browser sent a request that this server could not understand.
Apache/2.4.7 (Ubuntu) Server at 34.211.192.31 Port 80 CLOSED
it says bad request. maybe im wrong with the code. Can anyone help me?
