Put a Word in front of the Variable
hey guys,
my wish is to define a Variable with a word in front of it.
For example i got a humidity and a temperature sensor. These are working and i get a signal from it.
At the moment my program says by 1 send temperature by 2 humidity.
Is it available to program my code that instead of 1 or 2 i get a word like: for 1 temperature, for 2 humidity.
I am new in programming, sorry for questions like that.
my code is:
#include <RCSwitch.h>
#include <dht.h>
RCSwitch mySwitch = RCSwitch();
dht DHT;
#define DHT11_PIN 3
  mySwitch.enableTransmit(10);  // Der Sender wird an Pin 10 angeschlossen
  int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
  mySwitch.send(1, 24);
  mySwitch.send( DHT.temperature, 24);// Der 433mhz Sender versendet die Temperatur
  mySwitch.send(2, 14);
  mySwitch.send( DHT.humidity, 24) ;    //Der 433mhz Sender versendet die Luftfeuchtigkeit
  delay(1000);  // Eine Sekunde Pause, danach startet der Sketch von vorne
Would be nice if u can help me.
What does the send() function take as its parameters ?
Where did you get the "RCSwitch" library?
