I'm trying to make a device to keep track of the amount of drinks me and my roommates take from the fridge. I got it working, but at the moment the names are defined in the code. However, I would prefer to read the names from a .txt file on a SD card.
The .txt file has the following format:
Freddy\n
Bambi\n
Gertje\n
Loekie\n
Mattie\n
Johnny\n
Floem\n
Elmo\n
Edt\n
Ronnie\n
Pieter\n
Vlaaij\n
Bram\n
Kruimel\n
Tommie\n
Lynn\n
Teddy
How i do this right now:
- Make an array of size 25 (most likely there will be no more then 25 names to keep track of)
- Fill this array with the names from the .txt file
- Use the array in the rest of the code
//Outside the setup because I need these further down in the code
const int pinCS = 53; //pin for SD card initialization
String huisnamen0[25]; //Array to store the names
//Start the serial communication
//Define pinCS output
pinMode(pinCS, OUTPUT);
//Initialise SD card
SD.begin(pinCS);
char inputCharString[20]; //To keep track of each read character
char inputChar; //To store the last read character
int stringIndex = 0; //To keep track of the place in the inputCharString
//Open the .txt file
myFile = SD.open("HUISNA~1.TXT");
//Make sure it has opened before running the following code
if (myFile) {
Serial.print("huisnamen.txt:");
//Something left to read
while (myFile.available()) {
//Get the next character
inputChar = myFile.read();
//Check the type of the character
if ((inputChar >= 'a' && inputChar <= 'z') || (inputChar >= 'A' && inputChar <= 'Z') || (inputChar >= '0' && inputChar <= '9')) {
//Put the read character in the string on the correct place
inputCharString[stringIndex] = inputChar;
//Increase the index to put the next character in the next spot
stringIndex++;
//For debugging print some info to the serial monitor
Serial.println("stringIndex: " + String(stringIndex));
Serial.println("inputString: " + String(inputCharString));
//If an enter is encountered it means the end of the line and the name is reached
else if (inputChar == '\n') {
//For debugging print the name that is just read
Serial.print("De naam is: ");
Serial.println(inputCharString);
//Put the read name into the array that stores the names
huisnamen0[huisnamenIndex] = inputCharString;
//Increase the index to put the next name in the next spot
huisnamenIndex++;
//Put the index for the inputCharString back to 0. This means the first character of the next name will again be put on the first spot of the inputCharString
stringIndex = 0;
//Reset the inputCharString array in case the next name is shorter than the last
memset (inputCharString, 0, sizeof(inputCharString));
//Exit the while loop because the .txt file is empty
//Because the last name is not followed by an enter input the last name into the huisnamen0 array
//Done with the file so close it
myFile.close();
//For debugging print each value in the huisnamen0 array to check if it has read the names correctly
for(int i = 0; i < 24; i++) {
Serial.println("huisnamenIndex: " + String(i));
Serial.println("Huisnaam: " + String(huisnamen0[i]));
//If the file didn't open, print an error:
else {
Serial.println("error opening huisnamen.txt");
But the problem with this is that if I put less than 25 names into the .txt file, for example 15, the last 10 entries of the huisnamen0 array will be empty and cause errors in the rest of my program.
So what I would like to do is:
Initialize an array with size 25
Fill it with the names from the .txt file
Resize the array to the correct size
or -
Initialize an array of undefined size
or -
First check how many names there are in the .txt file
Initialize an array with this size
Even after spending a few evenings doing research on how to tackle this I haven't gotten any closer to an answer. I've tried to be as clear as possible, so I hope anyone can help me!
