Put me out my misery! Simple Wifi test not working!
Ok, trying to simply follow the tutorial on this page:
  • Arduino Uno / IDE 1.05
  • Copy/pasted the code to check I've got it spot on
  • Set my Wifi SSID/Pass
  • Ran Sketch
All connects to wifi fine, however get :
connection failed
disconnecting.
in Serial Monitor.
Any ideas on how I can debug/fix this? It's like it's struggling to see this page:
http://www.arduino.cc/latest.txt
Many thanks in advance?
Do other wifi sketches work?
Can you post your code? I assume you have modified it a bit after downloading...
Have you upgraded the firmware in your wifi shield? If you are using IDE v1.0.5 or v1.5.5, then you probably need to upgrade.
edit: For info on upgrading, read this post and follow the link there.
http://forum.arduino.cc/index.php?topic=206765.msg1521117#msg1521117
Hi folks,
Robtillart: nope, code exactly like link - deliberately keeping simple to debug this problem. Only change is my ssid and wifi password...and no you can't see them! :wink:
Surfertim: hmmm that seems like a likely suspect. Before I go through the whole process, is there an easy way to check the current version of the wifi shield firmware? That way I can confirm before I leap!
fair enough
alphabeta279:
Yes. The post on the link above has a short sketch that displays the firmware version. If it shows 1.0.0, then you need an upgrade. If it shows 1.1.0, then you don't. If you need an upgrade follow the link on that post to help you through the upgrade process.
Ah, sorry don't know how I missed that! Am on version 1.0.0, so let's see if we can upgrade!
Ok, genius! It's worked, am flashed to firmware 1.1.0 and have run a quick check of the wifirepeating demo which works great:
Have repointed to my local network server and it's now reading my website code beautifully, my LEDs will very shortly be being controlled by my dynamic CMS content!
Thanks very much for your help, it's much appreciated!
