Hello, everyone.
I am very new to arduino programming. I am trying to generate PWM signal at 40kHz with duty cycle change between 0% to 50%. In other words, I am trying to turn this 40kHz singal on and off for every few periods. Is it doable to put the OCR1A setting into a loop to achieve this varable duty cycle?
Here is my code.
#include <avr/sleep.h>
#include <avr/power.h>
byte pattern = 0b10101010; //consecutive ports will have an opposite signal
//Port Registers: DDRC=>analog input pins, determine which pin is input/output, PORTC controls whether the pin is HIGH or LOW)
DDRC = 0b00011111; //set pins A0 to A4 as outputs
PORTC = 0b00000000; //output low signal in all of them
// initialize timer1
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
ICR1= 399; //16Mhz /(399+1) =40kHz In fast PWM top=ICR1, the output PWM frequency=timer clock/(ICR1+1) and the duty=OCR1A(B)/ICR1
OCR1A = 199; //Control PWM duty cycle %*ICR1
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS10); // 1 prescaler, no prescaling
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
interrupts(); // enable all interrupts
// disable ADC
ADCSRA = 0;
// turn off everything we can
power_adc_disable ();
power_spi_disable();
power_twi_disable();
power_timer0_disable();
power_usart0_disable();
//while(true); //avoid entering into the loop
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
PORTC = pattern; //output portDV into ports 0 to 7
pattern = ~pattern; //invert all the bits
void loop(){
// if (OCR1A == 199)
OCR1A == 79;
delay(30);
if (OCR1A == 79)
OCR1A == 199;
delay(30); // something like...
Thank you very much!!!
