put these into a Uno
I have just purchased the following 2x ATMEGA328-PU Arduino UNO Bootloader,
Will i be able to drop these chips direct into my Uno and program them?.
Thanks.
If they have a boot loader already they should work fine.
You may get a Signature Byte error. If you do, its pretty easy to make a file change to have them recognized.
Thanks.
CrossRoads:
how to fix signature byte error?????
xvjeko:
CrossRoads:
You need to tweak the avrdude.conf file to include sections for the chip variation you have. You describe its signature and fuses. Search for avrdude.conf here.
Take a look at this:
Find avrdude.conf in this folder:
C:\Arduino-1.0.1\hardware\tools\avr\etc
copy the '328 section and paste it at the end.
Change the couple of lines I have indicated with <<< below
ATmega328P <<< <<< change to ATMEGA328
part
id = “m328p”; <<< change to m328
desc = “ATMEGA328P”; <<< change to ATMEGA328
has_debugwire = yes;
flash_instr = 0xB6, 0x01, 0x11;
eeprom_instr = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
0x99, 0xF9, 0xBB, 0xAF;
stk500_devcode = 0x86;
avr910_devcode = 0x;
signature = 0x1e 0x95 0x0F; <<< change to 0x1E 0x95 0x14 >>> I think rest of this stays the same
pagel = 0xd7;
bs2 = 0xc2;
chip_erase_delay = 9000;
pgm_enable = “1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1”,
“x x x x x x x x x x x x x x x x”;
chip_erase = “1 0 1 0 1 1 0 0 1 0 0 x x x x x”,
timeout = 200;
stabdelay = 100;
cmdexedelay = 25;
synchloops = 32;
bytedelay = 0;
pollindex = 3;
pollvalue = 0x53;
predelay = 1;
postdelay = 1;
pollmethod = 1;
pp_controlstack =
0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
hventerstabdelay = 100;
progmodedelay = 0;
latchcycles = 5;
togglevtg = 1;
poweroffdelay = 15;
resetdelayms = 1;
resetdelayus = 0;
hvleavestabdelay = 15;
resetdelay = 15;
chiperasepulsewidth = 0;
chiperasepolltimeout = 10;
programfusepulsewidth = 0;
programfusepolltimeout = 5;
programlockpulsewidth = 0;
programlockpolltimeout = 5;
memory “eeprom”
paged = no;
page_size = 4;
size = 1024;
min_write_delay = 3600;
max_write_delay = 3600;
readback_p1 = 0xff;
readback_p2 = 0xff;
read = " 1 0 1 0 0 0 0 0",
" 0 0 0 x x x a9 a8",
" a7 a6 a5 a4 a3 a2 a1 a0",
" o o o o o o o o";
write = " 1 1 0 0 0 0 0 0",
" i i i i i i i i";
loadpage_lo = " 1 1 0 0 0 0 0 1",
" 0 0 0 0 0 0 0 0",
" 0 0 0 0 0 0 a1 a0",
" i i i i i i i i";
writepage = " 1 1 0 0 0 0 1 0",
" 0 0 x x x x a9 a8",
" a7 a6 a5 a4 a3 a2 0 0",
" x x x x x x x x";
mode = 0x41;
delay = 20;
blocksize = 4;
readsize = 256;
memory “flash”
paged = yes;
size = 32768;
page_size = 128;
num_pages = 256;
min_write_delay = 4500;
max_write_delay = 4500;
readback_p1 = 0xff;
readback_p2 = 0xff;
read_lo = " 0 0 1 0 0 0 0 0",
" 0 0 a13 a12 a11 a10 a9 a8",
" o o o o o o o o";
read_hi = " 0 0 1 0 1 0 0 0",
" o o o o o o o o";
loadpage_lo = " 0 1 0 0 0 0 0 0",
" 0 0 0 x x x x x",
" x x a5 a4 a3 a2 a1 a0",
" i i i i i i i i";
loadpage_hi = " 0 1 0 0 1 0 0 0",
" 0 0 0 x x x x x",
" i i i i i i i i";
writepage = " 0 1 0 0 1 1 0 0",
" a7 a6 x x x x x x",
" x x x x x x x x";
mode = 0x41;
delay = 6;
blocksize = 128;
readsize = 256;
memory “lfuse”
size = 1;
read = “0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0”,
“x x x x x x x x o o o o o o o o”;
write = “1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0”,
“x x x x x x x x i i i i i i i i”;
memory “hfuse”
size = 1;
read = “0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0”,
write = “1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0”,
memory “efuse”
size = 1;
read = “0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0”,
“x x x x x x x x x x x x x o o o”;
write = “1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0”,
“x x x x x x x x x x x x x i i i”;
memory “lock”
size = 1;
read = “0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0”,
“x x x x x x x x x x o o o o o o”;
write = “1 0 1 0 1 1 0 0 1 1 1 x x x x x”,
“x x x x x x x x 1 1 i i i i i i”;
memory “calibration”
size = 1;
read = “0 0 1 1 1 0 0 0 0 0 0 x x x x x”,
“0 0 0 0 0 0 0 0 o o o o o o o o”;
memory “signature”
size = 3;
read = “0 0 1 1 0 0 0 0 0 0 0 x x x x x”,
“x x x x x x a1 a0 o o o o o o o o”;
Find boards.txt in this folder:
C:\Arduino-1.0.1\hardware\arduino
Copy this section, paste it at end, make these changes as indicated by <<<
In both cases, I used free download of Notepad++ for editing, lot easier than fighting with Notepad to do it
I don’t have a 328 chip to try it, but I believe this is what is needed.
uno.name=Arduino Uno with 328 <<<<<<< added ‘with 328’
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
uno.bootloader.path=optiboot
uno.bootloader.file=optiboot_atmega328.hex
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.build.mcu=atmega328 <<<<< removed ‘p’ at the end
uno.build.f_cpu=16000000L
uno.build.core=arduino
uno.build.variant=standard
