Hello,
Does anyone know of any good tutorials of how to put an LM35 temperature sensor reading online?I’m using an ethernet shield. I’ve found some for a DS18B20 but have not had much luck with the LM35.
Any help is greatly appreciated!
Jack
Hello,
Jack
It will be no different than the DS18B20, just change the code to read the DS to the LM chip. The ‘online’ bit will be the same.
Thanks for the reply!
Do you know how this might be done?My coding experience isn’t the strongest. The code i’m using for the temperature sensor aspect is below
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
digitalWrite(Pin, LOW);
pinMode(Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
void getCurrentTemp(char *temp)
int HighByte, LowByte, TReading, Tc_100, sign, whole, fract;
OneWireReset(TEMP_PIN);
OneWireOutByte(TEMP_PIN, 0xcc);
OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN);
HighByte = OneWireInByte(TEMP_PIN);
TReading = (HighByte << 8) + LowByte;
sign = TReading & 0x8000; // test most sig bit
if (sign) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
whole = Tc_100 / 100; // separate off the whole and fractional portions
fract = Tc_100 % 100;
if(sign) temp[0]='-';
else temp[0]='+';
if(whole/100==0)
temp[1] =' ';
temp[1]= whole/100+'0';
temp[2]= (whole-(whole/100)*100)/10 +'0' ;
temp[3]= whole-(whole/10)*10 +'0';
temp[4]='.';
temp[5]=fract/10 +'0';
temp[6]=fract-(fract/10)*10 +'0';
temp[7] = '\0';
Thanks in advance
Jack
Isn’t the LM35 an analogue device?
You need to put it on an analogue input, and figure on 10mV per degree.
