I am trying to use Nano as a datalogger by turning it on and off at set intervals. While I achieve this very easily on Mini D1 (Board with onboard Wifi) I cant get any other board such as Uno or Nano to go to sleep. The power LED is always on when using the following code.
SIM5320 only turns on on the Nano when using 5V pin which is another challenge. I tried using HIGH and LOW on other pins and connect but I guess there is not enough current to turn on SIM5320.
This for example, ESP.deepSleep(5e6), easily puts Mini D1 to sleep without any effort.
#include "LowPower.h"
// No setup is required for this library
// Enter power down state for 8 s with ADC and BOD module disabled
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
// Do something here
// Example: Read sensor, data logging, data transmission.
Serial.print("waking up");
