Hi, Can anyone possibly help? I've been trying to get my head around this problem for quite a while now. I've searched the net and these forums but I either dont understand enough or the OPoster doesn't explain how they fixed the problems anyway...
I get this massive error which looks like something is missing or it cant find some files but I'm not sure how to fix the issue.
Im using arduino 1.0 and this is the link to the firmware:https://github.com/repetier/Repetier-Firmware#readme
Any help would be mega useful,
Many many thanks in advance!
In file included from Commands.cpp:22:
Reptier.h:226:19: error: Print.h: No such file or directory
Reptier.h:229:21: error: Arduino.h: No such file or directory
Commands.cpp:26:26: error: pins_arduino.h: No such file or directory
In file included from Reptier.h:234,
gcode.h:38: error: 'byte' does not name a type
gcode.h:82: error: expected class-name before '{' token
gcode.h:113: error: 'Print' has not been declared
gcode.h:124: error: expected class-name before '{' token
gcode.h:167: error: 'byte' does not name a type
gcode.h:168: error: 'byte' has not been declared
gcode.h:191: error: 'byte' does not name a type
In file included from Reptier.h:245,
ui.h:394: error: 'byte' does not name a type
ui.h:395: error: 'byte' does not name a type
ui.h:396: error: 'byte' does not name a type
ui.h:397: error: 'byte' does not name a type
ui.h:399: error: 'byte' does not name a type
ui.h:411: error: 'byte' has not been declared
ui.h:413: error: 'byte' has not been declared
ui.h:422: error: 'byte' has not been declared
ui.h:422: error: expected ',' or '...' before 'charmap'
ui.h:422: error: ISO C++ forbids declaration of 'byte' with no type
ui.h:424: error: 'byte' has not been declared
ui.h:425: error: 'byte' has not been declared
ui.h:772: error: variable or field 'beep' declared void
ui.h:772: error: 'byte' was not declared in this scope
Reptier.h:302: error: 'byte' does not name a type
Reptier.h:303: error: 'byte' does not name a type
Reptier.h:304: error: 'byte' does not name a type
Reptier.h:313: error: 'byte' does not name a type
Reptier.h:314: error: 'byte' does not name a type
Reptier.h:318: error: 'byte' does not name a type
Reptier.h:321: error: 'byte' does not name a type
Reptier.h:331: error: 'byte' does not name a type
Reptier.h:335: error: 'byte' does not name a type
Reptier.h:338: error: 'byte' does not name a type
Reptier.h:356: error: 'byte' does not name a type
Reptier.h:357: error: 'byte' does not name a type
Reptier.h:365: error: 'byte' does not name a type
Reptier.h:380: error: variable or field 'extruder_select' declared void
Reptier.h:380: error: 'byte' was not declared in this scope
Reptier.h:384: error: 'byte' has not been declared
Reptier.h:388: error: variable or field 'extruder_set_direction' declared void
Reptier.h:388: error: 'byte' was not declared in this scope
Reptier.h: In function 'void extruder_step()':
Reptier.h:404: error: 'HIGH' was not declared in this scope
Reptier.h: In function 'void extruder_unstep()':
Reptier.h:446: error: 'LOW' was not declared in this scope
Reptier.h: At global scope:
Reptier.h:483: error: variable or field 'extruder_set_direction' declared void
Reptier.h:483: error: 'byte' was not declared in this scope
