I'm using a SAMD21G18A based board - the arduino zero, for a battery-powered wearable project (a type of computer mouse). I'm trying to figure out how to put the device to sleep, when it hasn't been moved for a period of time. I'm using data from a connected gyroscope, which is stored into an array. If the sum of the data in the array is less than some threshold, then I put the device into sleep using the sleep function from the arduino low-power library. I'm waking the device with an interrupt from the sensor.
void nomotion_sleep(float x_value) {
static float sleep_threshold = 15;
static float sleep_array[15];
static byte sa_size = 15;
static float asum; // array sum
static byte i = 0;
static uint32_t array_timer;
if (timer1(array_timer, 60000)) { // a timer f, checks every min
sleep_array[i] = abs(x_value); //x_value is from the gyro
asum += sleep_array[i];
i += 1;
if (i == sa_size - 1) {
if (asum < sleep_threshold) {
//sleep
LowPower.sleep();
for (byte ii = 0; ii < sa_size; ii += 1) {
sleep_array[i] = 0;
asum = 0;
i = 0;
The above code is my attempt to do this, but I'm not sure if I need to erase the asum value somehow, if the device goes to sleep. And not sure how to do this. Maybe upon wake up in the function called by the interrupt?
Is there a better way to do this? Thank you for trying to help.
