Hi All,
I'm currently working on a project with a few people for a golf putting sim to practice and to possibly connect it to a few golf sim software's.
Here is a bit of information on my project:
I'm currently using two SharpIR 10-80cm sensors to calculate inputs for the golf software. These sensors would be set at a known distance apart from each other and the sensors would be pointing across the putting mat. You calculate the speed of the ball by the time it takes to roll past both sensors.
You would calculate the horizontal launch angle or path of the ball by drawing an imaginary triangle and solving the angles. The sensors are constantly reporting distance to an object. So I might place a piece of wood at a constant distance or create a limit in the code such that the sensors will always report the same distance unless an object passes them. The thought would be to detect a change in the data stream whenever the ball rolls by and use those values to solve the whole equation. The setup would look like my drawing.
Now, the path of the ball is solved by finding the arctan of the distance between the actual sensors (x) and the difference between the reported values from the sensors (S2-S1=y) so we have atan(y,x). This works just fine.
I'm having issues calculating speed of the ball. I have a velocity equation in the code to calculate speed however it's not doing this correctly. We tried to create a trigger or timer once the ball rolls past the first sensor and then obviously its stopped when the second sensor is triggered. When I open the serial monitor I get this reported for speed "inf". So there is some kind of issue here. Another issue is that it doesn't seem to wait for the second sensor, meaning if you trigger sensor one it complete the loop and says "Sensor One Triggered" "Sensor Two Triggered" "Speed inf" and "HLA xx". So I'm not sure why its not waiting for the second sensor.
Could you guys take a look at my code and let me know what you think the issues are?
#include <SharpIR.h>
#define IR1 A1 // define signal pin
#define IR2 A2 // define signal pin
#define model1 1080 // for GP2Y0A21YK0F used 1080
#define model2 1080 // for GP2Y0A21YK0F used 1080
#define defaultDistance 200 // distance from wood in mm
#define allowedVariance .05 // percentage variance
// Sharp IR code for Robojax.com
// ir: the pin where your sensor is attached
2 to 15 cm GP2Y0A51SK0F use 215
4 to 30 cm GP2Y0A41SK0F / GP2Y0AF30 series use 430
10 to 80 cm GP2Y0A21YK0F use 1080
10 to 150 cm GP2Y0A60SZLF use 10150
20 to 150 cm GP2Y0A02YK0F use 20150
100 to 550 cm GP2Y0A710K0F use 100550
SharpIR SharpIR1(1, IR1);
SharpIR SharpIR2(1, IR2);
unsigned long timeSensorOne=0;
unsigned long timeSensorTwo=0;
double velocity;
double angleDegree;
double calculateVelocity (unsigned long startTime, unsigned long endTime) {
return 609.6/((endTime-startTime)/1000);
double calculateHLA (float distSensorOne, float distSensorTwo) {
//Find the HLA using Arctan of y,x
double x = 609.6; //distance between sensors in mm
double y = distSensorTwo-distSensorOne;
double angleRadian;
angleRadian = atan2(y,x);
return angleRadian*180/3.14159265;
Serial.println("Putting SIM ");
// extra pin for 5V if needed
pinMode(3, OUTPUT); // define pin x as output
digitalWrite(3, HIGH);// set pin x HIGH so it always have 5V
// Wait 10 milliseconds
delay(100);
// Get distance from sensor one;
float distSensorOne = (SharpIR1.getDistance()*10.);
// Get time of sensor one distance;
timeSensorOne = millis();
//Serial.println((String)"Sensor One Distance: "+distSensorOne+"mm");
// if sensor one detects change and is more than allowed variance
if (distSensorOne < defaultDistance * (1 - allowedVariance)){
Serial.println("Sensor One Triggered!");
//for the next 50 milseconds, lets see if sensor two is triggered
while (millis() - timeSensorOne <= 50) {
// Get distance from sensor two;
float distSensorTwo = (SharpIR2.getDistance()*10.);
timeSensorTwo = millis();
// if sensor two detects change and is more than allowed variance
if (distSensorTwo < defaultDistance * (1 - allowedVariance)){
Serial.println("Sensor Two Triggered!");
//Calculate and Print Speed
velocity = calculateVelocity(timeSensorOne, timeSensorTwo);
Serial.print("Speed ");
Serial.print(velocity);
Serial.println(" mph");
//Calculate and Print value for HLA
angleDegree = calculateHLA(distSensorOne, distSensorTwo);
Serial.print("HLA: ");
Serial.println(angleDegree);
break; }
