Putting three codes together
Hello,
I'm doing a project and I'm trying to make a servo turn using two button, an LRD, and a sound sensor. I have three different codes for each componant but I am having a lot of trouble putting them all in one main code. I put all the three codes below. Thank you!
Buttons:
#include <Servo.h>
Servo myservo;  // name servo
int angle =90;    // initial angle  for servo
int angleStep =5; //speed
int redLED=4;
int greenLED=5;
#define greenButton 2   // pin 2 is connected to green button
#define redButton  3  // pin 3 is connected to red button
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(greenButton,INPUT_PULLUP); // assign pin 12 as input for Left button.
  pinMode(redButton,INPUT_PULLUP);// assing pin 2 as input for right button.
  pinMode(greenLED,OUTPUT);
  pinMode(redLED, OUTPUT);
  myservo.write(angle);// send servo to the middle at 90 degrees (initial angle)
  digitalWrite(greenLED, LOW);
  digitalWrite(redLED, LOW);
  while(digitalRead(redButton) == LOW){
    if (angle > 20 && angle <= 100) {
      angle = angle - angleStep;
       if(angle < 20){
        angle = 20;
       }else{
      myservo.write(angle); // move the servo to desired angle
      digitalWrite(greenLED, HIGH);
  delay(5); // waits for the servo to get there
  }// while
  while(digitalRead(greenButton) == LOW){
    if (angle >= 20 && angle <= 100) {
      angle = angle + angleStep;
      if(angle >100){
        angle =100;
       }else{
      digitalWrite(redLED, HIGH);
LRD:
#include <Servo.h> // include Servo library
Servo myservo; // horizontal servo
int servoh= 90; // stand horizontal servo
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
// servo connections
// name.attacht(pin);
  myservo.attach(9);
  int lt = analogRead(ldrlt); // top left
  int rt = analogRead(ldrrt); // top right
  int ld = analogRead(ldrld); // down left
  int rd = analogRead(ldrrd); // down rigt
  int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < 0)
servoh = 0;
else if (avl < avr)
servoh = ++servoh;
if (servoh > 180)
servoh = 180;
else if (avl == avr)
// nothing
myservo.write(servoh);
delay(dtime);
Sound sensor:
#include <Servo.h>
Servo servo;
* global variables                         *
const byte analog_pin = A2;          //connected to envelope pin of
                                                        //sparkfun sound detector
const byte threshold = 70;           //value determined through        //experimentation
int servo_pin = 9;
int lamp_state = 0;  //stores current lamp_state
int greenLED =  5;// 0 for OFF, 1 for ON
int redLED = 4;
* setup                                   *
void setup(){
  pinMode(analog_pin, INPUT);
  servo.attach(servo_pin);
  pinMode(greenLED, OUTPUT);
* main loop                               *
void loop(){
  int analog_value = analogRead(analog_pin);   //read and store envelope //value from sf sound detector
  //if analog value is greater than threshold
  if(analog_value > threshold){
    lamp_state = !lamp_state;    //toggle value of lamp state variable
                                 //if lamp_state was 0, flip it to 1
                                 // if lamp_state was 1, flip it to 0
    if(!servo.attached()){       //if servo not attached, attach it
      servo.attach(9);
    if(lamp_state == 1){      //if lamp_state is 1,
   //switch ON
    delay(500);  //helps reduce false triggering
      //servo.write values determined through experiment
      //specific linkage design, length, etc.,
      //will dictate the ON/OFF write values needed
      //1)mount servo
      //2) disconnect linkage from switch
      //3) snap fingers
      //4) note distance and direction servo moves linkage when
      //e.g., 45, 90, etc., are written to servo
      //increase/decrease write values until
      //the correct "throw" is achieved
    servo.write(100);      //lamp ON
      delay(1000);        //helps to prevent false triggering
      servo.detach();
      digitalWrite(greenLED,LOW);
      digitalWrite(redLED,HIGH);
    else{
      servo.write(20);      //lamp OFF
      servo.detach();
      digitalWrite(greenLED,HIGH);
      digitalWrite(redLED,LOW);
}     //    <-------- end of main loop
Welcome to the forum. Please read the instructions at the top of the forum about how to properly post your code using code tags. It will help others help you.
All I see are three different sketches. Please post your attempt at putting them together, along with any errors you are getting as we can help you.
Sorry for the incovenience, here is our attempt. When we put them together, our LED lights are on at the same time, the buttons work but the sound sensor and the LRDs don't work.
#include <Servo.h>
int redLED=4;
int greenLED=5;
int servoh= 90;
const byte threshold = 200;
int servo_pin = 9;
int lamp_state = 0;
  myservo.attach(servo_pin);
  if(digitalRead(redButton) == LOW){
       if(angle < 20){
        angle = 20;
       }else{
    }  delay(5); // waits for the servo to get there
else if (-1*tol > dhoriz || dhoriz > tol) {// check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr){
servoh = --servoh;
if (servoh < 0){
servoh = 0;
else if (avl < avr){
servoh = ++servoh;
if (servoh > 180){
servoh = 180;
delay(dtime);
 if(digitalRead(greenButton) == LOW){
      if(angle >100){
        angle =100;
       }else{
    delay(5);
  else if(analog_value > threshold){
    if(!myservo.attached()){
      myservo.attach(9);
   myservo.write(100);      //lamp ON
    delay(250);
    myservo.detach();
 else{
      myservo.write(20);      //lamp OFF
      delay(250);
      myservo.detach();
@OP
Your all 3 separate sketches are combined and compiled without error. Check that A2-pin of Sound Control sketch is now changed to A6-pin A4-pin. Please, check the functionality of the program.
#include <Servo.h>
int angle = 90;   // initial angle  for servo
int angleStep = 5; //speed
int redLED = 4;
int greenLED = 5;
int servoh = 90; // stand horizontal servo
const byte analog_pin = A6;//A2;          //connected to envelope pin of
  pinMode(greenButton, INPUT_PULLUP); // assign pin 12 as input for Left button.
  pinMode(redButton, INPUT_PULLUP); // assing pin 2 as input for right button.
  buttonControl();
  ldrControl();
  soundControl();
void buttonControl()
  while (digitalRead(redButton) == LOW)
      if (angle < 20)
        angle = 20;
  }// while
  while (digitalRead(greenButton) == LOW)
      if (angle > 100)
        angle = 100;
      } else
void ldrControl()
  int dtime = analogRead(4) / 20; // read potentiometers
  int tol = analogRead(5) / 4;
  if (-1 * tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
    if (avl > avr)
      servoh = --servoh;
      if (servoh < 0)
        servoh = 0;
    else if (avl < avr)
      servoh = ++servoh;
      if (servoh > 180)
        servoh = 180;
      // nothing
  delay(dtime);
void soundControl()
  if (analog_value > threshold)
    if (!myservo.attached())
      myservo.attach(9);
    if (lamp_state == 1)
      //switch ON
      //1)mount servo
      //3) snap fingers
      myservo.detach();
      myservo.detach();
Hello,
I am trying to make a servo motor turn in two different directions using two buttons, LRD and sound sensor. I have three seperate codes for each componant but I am having a lot of trouble putting them all in one main code. When I tried only the buttons worked and both the LED lights are on at the same time. Here is the code that i tried with all three codes. Thank you!
#include <Servo.h>
int redLED=4;
int greenLED=5;
int servoh= 90;
int servo_pin = 9;
int lamp_state = 0;
       if(angle < 20){
        angle = 20;
       }else{
if (avl > avr){
servoh = --servoh;
if (servoh < 0){
servoh = 0;
servoh = ++servoh;
if (servoh > 180){
servoh = 180;
delay(dtime);
      if(angle >100){
        angle =100;
       }else{
    delay(5);
      myservo.attach(9);
    delay(250);
    myservo.detach();
 else{
      delay(250);
      myservo.detach();
on your first post, go to the end of it and hit edit
at the begining of your code, type the word code and surround with brackets [ ]
at the end of your code, type /code
save
Thank you!
Hello,
Thank you so much for your time and help. I didn' know you could add void loops, but there's a small problem that I can't seem to understand: the buttons and the LED lights are working perfectly but the sound sensor and the LDR aren't. I verified all the wiring and it seems to be ok, do you know any solutions?
How do you know this?
I verified the code and circuit with the breadboard
You verified what code?
How do you know the sensors aren't working?
I verified the code that was sent to me earlier and it didnt work with the cicuit that I made with the breadbord.
OK.
Have a look at this Simple Merge Demo
Before trying to merge the programs go through each of them carefully to make sure they are not trying to use the same resource - for example an I/O pin. If you find conflicts change something in one of the separate programs and make sure it still works with the change.
...R
Planning and Implementing a Program
Do you have an idea as to what we could do? It would be very helpful, Thank you!
Start with some debug prints.
Here's a approach to this; maybe use Robin's example as first attempt..
https://arduinoinfo.mywikis.net/wiki/CombiningArduinoSketches
I am new to Arduio and I've been trying to merge three sketches in one main code. I've been working on it for hours and I still can't get it to work. The first code consists of two buttons that control the servo motor and LEDs light up when the servo reaches the correct position, the second is the same but instead of buttons I used two light sensors, and the third is the same but with a sound sensor(I clap). Here is an attempt.
#include <Servo.h>
int redLED = 4;
int greenLED = 5;
const byte analog_pin = A4;//A2;          //connected to envelope pin of
  buttonControl();
  ldrControl();
  soundControl();
      if (angle < 20)
        angle = 20;
  }// while
      if (angle > 100)
        angle = 100;
      } else
void ldrControl()
    if (avl > avr)
      servoh = --servoh;
      if (servoh < 0)
        servoh = 0;
    else if (avl < avr)
      servoh = ++servoh;
      if (servoh > 180)
        servoh = 180;
      // nothing
  delay(dtime);
void soundControl()
      myservo.attach(9);
      //switch ON
      //1)mount servo
      //3) snap fingers
      myservo.detach();
      myservo.detach();
Tell us some stuff:
Does it verify OK??
What is it SUPPOSED to do??
Not quite sure why you decided to create a new account for this, but I merged your topics anyway.
