So I'm working on a simple MIDI synth, and this one part of the program has got me puzzled as to why it doesn't work.
I took out a lot of the program, to isolate the problem. So now, when any MIDI note is received, it should play a 440 hertz tone. (or some octave of it).
I'm using 2 timers to create the tone. One to create a PWM signal that is filtered to get an analog output. The other runs a interrupt function that updates the output.
Here is the code:
#include <WProgram.h>
#include <MIDI.h>
#include "osc.h"
MIDI_Class input;
osc osc1;
volatile int currentIndex;
int currentWave = 0;
volatile unsigned long clock;
cli();
pinMode(11, OUTPUT); //set OC2A pin to output
TCCR2A |= 1 << WGM20; // \
TCCR2A |= 1 << WGM21; // }- Set timer to phase fast PWM mode
TCCR2B &= ~(1 << WGM22); // /
TCCR2A |= 1 << COM2A1; // }- Set to non-inverting PWM
TCCR2A &= ~(1 << COM2A0); // /
TCCR2B |= 1<< CS20; // \
TCCR2B &= ~(1 << CS21); // }- Set to prescalar of 1 (no prescalar).
TCCR2B &= ~(1 << CS22); // / 62500 Hz PWM
//Setting up timer1 for CTC mode
TCCR1A &= ~(1 << WGM10);
TCCR1A &= ~(1 << WGM11);
TCCR1B |= 1 << WGM12;
TCCR1B &= ~(1 << WGM13);
//Prescalar 1
TCCR1B |= 1<< CS10;
TCCR1B &= ~(1 << CS11);
TCCR1B &= ~(1 << CS12);
unsigned char sreg;
sreg = SREG;
OCR1A = 199;
SREG = sreg;
TIMSK1 |= (1 << OCIE1A); // Enable CTC interrupt
sei();
pinMode(6, OUTPUT);
digitalWrite(6, HIGH);
input.begin(MIDI_CHANNEL_OMNI);
input.turnThruOff();
//osc1.setFreq(clock, 440);
//Waveform select code \/ \/ \/
int reading = analogRead(5);
if(reading < 300) {
osc1.setWaveform(0);
else if(reading > 700) {
osc1.setWaveform(2);
else {
osc1.setWaveform(1);
//End waveform select
//MIDI handling code \/ \/ \/
if(input.read() == true) {
//End MIDI handling code
ISR(TIMER1_COMPA_vect) {
clock += 10;
byte output;
output += osc1.refresh(clock);
OCR2A = output;
Here is osc.h:
class osc {
public:
osc();
byte refresh(unsigned long clock);
void setWaveform(int waveform);
void setFreq(unsigned long clock, int hertz);
static const byte _waves[3][16];
private:
int _currentStep;
unsigned long _ticks;
unsigned long _lastStep;
int _waveform;
byte _on;
const byte osc::_waves[3][16] = {
0x0, 0x2, 0x4, 0x6,
0x8, 0xa, 0xc, 0xe,
0xf, 0xe, 0xc, 0xa,
0x8, 0x6, 0x4, 0x2
0xf, 0xf, 0xf, 0xf,
0xf, 0xf, 0xf, 0xf,
0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0
0xf, 0xe, 0xd, 0xc,
0xb, 0xa, 0x9, 0x8,
0x7, 0x6, 0x5, 0x4,
0x3, 0x2, 0x1, 0x0
osc::osc() {
byte osc::refresh(unsigned long clock) {
if(clock - _lastStep >= _ticks) {
_currentStep = (++_currentStep)%16;
_lastStep += _ticks;
return _waves[_waveform][_currentStep] *_on;
void osc::setWaveform(int waveform) {
_waveform = waveform;
void osc::setFreq(unsigned long clock, int hertz) {
if(hertz > 0) {
_ticks = 400000UL /(hertz * 4UL);
_on = 1;
_currentStep = 0;
_lastStep = clock;
else {
_on = 0;
Inside the if(input.read() == true) statement, the call to osc1.setFreq does not work.
MIDI notes are received correctly, because if I put a tone(11, 440) in the if statement, it makes a tone when I send it a midi note.
And the osc class does work correctly. If I call the setFreq function in either of the 2 places it is commented out (at the end of setup, or in the middle of loop), it plays the tone as expected. (although in loop, it sounds strange because it is called repeatedly)
So what would cause the function to not function inside the if statement?
