Puzzling behavior with modulo operator
define EEPROM_DBG_START 100
define EEPROM_MAX_CODES 50
define EEPROM_DBG_END EEPROM_DBG_START + EEPROM_MAX_CODES
unsigned int dbgAddress;
void setup() { unsigned int temp;
dbgAddress = EEPROM_DBG_START;
// put your setup code here, to run once: Serial.println(dbgAddress); dbgAddress++; Serial.println(dbgAddress);
Serial.println(EEPROM_DBG_END);
temp = dbgAddress; dbgAddress = temp % EEPROM_DBG_END; Serial.println(dbgAddress); }
The output is 100 101 150 51
I expected the output to be 100 101 150 101
#define EEPROM_DBG_END     (EEPROM_DBG_START + EEPROM_MAX_CODES)
Thanks. That works. When I printed EEPROM_DBG_END, it printed the correct value. So, it's strange that the modulo doesn't work as I expected.
No, that is not strange and the operator works as expected.
mod = value % modVal + sameValue;
is different to
mod = value % (modVal + sameValue);
and that is expected.
Got it now. Thanks.
If you use (at least for EEPROM_DBG_END)
const byte EEPROM_DBG_START = 100;
const byte EEPROM_MAX_CODES = 50;
const byte EEPROM_DBG_END = EEPROM_DBG_START + EEPROM_MAX_CODES;
you don’t need the braces around the addition.
#define uses textual replacement, so it is more context sensitive.
