PW Soft Start Script Customization
I have modified several battery operated ride-ons for my child. The majority of them being ESC conversions. I am new to Arduino, but have found a script on the MPW forum for using Arduino Uno R3/ATmega328 and an H-Bridge.
I would like to add an output pin for when the Arduino is powered it will ground a relay that will power all the LED lighting. After a timeout of five minutes with no pedal activity the uC will sleep and shut off the LED lighting relay until the throttle is pressed wakes the uC up.
The existing code is as such:
// Variables, Defines
// Direction
#define forward 1
#define stopped 0
#define reverse -1
// Commands
#define cmd_none   0
#define cmd_fwdlo  1
#define cmd_fwdhi  3
#define cmd_rev    4
// Input definitions
#define ON  LOW
// Input pin definitions
#define fwdpin1 5  // Low speed
#define fwdpin2 4  // High speed
#define revpin  2  // Reverse
// Output pin definitions
#define fwdpwm 9   // PWM for forward
#define revpwm 11  // PWM for reverse
// Variables
byte currentmode=stopped;  // To store current direction of motion
int pwmspeed=0;            // To store current commanded speed: value may be from -255 (reverse) to 255 (forward). Zero means stopped
byte command;              // to store Commands
// Values for accel/decel/braking
#define accel_ratelo  2
#define accel_ratehi  4
#define decel_rate    3
#define brake_rate    6
// Value for delay when changing direction without stopping first
#define directionchangedelay 1000
// values for maximum commanded motor speed (maximum is 255 for forward directions, and -255 for reverse)
#define maxfwd1  128
#define maxfwd2  180
#define maxrev  -128
  // Set up input & output pin modes
  pinMode(fwdpin1,INPUT_PULLUP);
  pinMode(fwdpin2,INPUT_PULLUP);
  pinMode(revpin,INPUT_PULLUP);
  pinMode(fwdpwm,OUTPUT);
  pinMode(revpwm,OUTPUT);
  //read the pin statuses
  command=readCommand();
  switch(command)
    case cmd_none:
      if(currentmode != stopped){
        slowdown();
    case cmd_fwdlo:
      forwardlo();
    case cmd_fwdhi:
      forwardhi();
    case cmd_rev:
      reverselo();
    default:
      //Error! ALL STOP!
      allstop();
int readCommand(){
  // Read the input pins and return a value for the current input state
  int count=0;
  if(digitalRead(fwdpin1)==ON){
    count+=1;
  if(digitalRead(fwdpin2)==ON){
    count+=2;
  if(digitalRead(revpin)==ON){
    count+=4;
  return count;
void slowdown(){
  // slows vehicle down when pedal is released
  if(pwmspeed>0){ // motor is currently set to forward
    pwmspeed-=decel_rate;
    if(pwmspeed<0){
      pwmspeed=0;
  } else
  if(pwmspeed<0){ // motor is current set to reverse
    pwmspeed+=decel_rate;
    if(pwmspeed>0){
      pwmspeed=0;
  commandMotor();
void forwardlo(){
  // moves vehicle foward up to low speed maximum
  if(currentmode==stopped){ // go from stopped to fwd1
    currentmode=forward;
    acceleratehi();
  } else
  if(currentmode==reverse){ // go from reverse to fwd 1
    brake();
  } else
  if(pwmspeed>maxfwd1){ // slow from fwd2 down to fwd1
    slowdown();
  } else
  if(pwmspeed<maxfwd1){ // continue to accelerate to fwd1
    acceleratehi();
void forwardhi(){
  if(currentmode==stopped){ // go from stopped to fwd2
    acceleratelo();
  } else
  if(currentmode==reverse){ // go from reverse to fwd2
    brake();
  } else
  if(pwmspeed<maxfwd2){  // continue to accelerate to fwd2
    acceleratelo();
void reverselo(){
  if(currentmode==stopped){   // go from stopped to reverse
    currentmode=reverse;
    acceleratelo();           // change to acceratehi() if you want to reverse at a quicker rate!
  } else
  if(currentmode==forward){   // go from fwd1/2 to reverse
    brake();
  } else
  if(pwmspeed>maxrev){        // continue to accelerate to reverse
void allstop(){
  // Emergency brake! Used when Error condition detected
  pwmspeed=0;
  commandMotor();
  delay(3000); // delay before starting up again
void acceleratehi(){
  // First gear! (also may be used for reverse if you want to reverse faster)
    pwmspeed+=accel_ratehi;
    pwmspeed-=accel_ratehi;
  commandMotor();
void acceleratelo(){
  // Second gear! (hence lower acceleration); note, also used for reverse
    pwmspeed+=accel_ratelo;
    pwmspeed-=accel_ratelo;
  commandMotor();
void brake(){
  // Stop at high rate, used when lever is changed direction and pedal is pressed before vehicle has come to a stop.
  if(pwmspeed>0){  // slow from forward direction
    pwmspeed-=brake_rate;
    if(pwmspeed<0){
      pwmspeed=0;
  } else
  if(pwmspeed<0){  // slow from reverse direction
    pwmspeed+=brake_rate;
    if(pwmspeed>0){
      pwmspeed=0;
  commandMotor();
  if(pwmspeed==0){    // add a delay (that'll teach 'em not to mess around with the lever!)
    delay(directionchangedelay);
void commandMotor(){
  // send the command to the motor
  if(pwmspeed==0){ // All stopped
    analogWrite(fwdpwm,0);
    analogWrite(revpwm,0);
  } else
  if(pwmspeed>0){ // forward motion
    analogWrite(fwdpwm,pwmspeed);
  } else {  // reverse motion
    analogWrite(revpwm,-1*pwmspeed);
A simple schematic. Factory wiring left. Modified Right.
Can anyone provide some simple code to this easily? I appreciate it.
