PWM 0-3.3V Convert to DC 0-10V. Max Current 10mA
I want to control an external System, which needs a variable 0-10V DC Input for controlling. I am able to put Software PMW to a Pin, nd controll ist varable as I need, but I need to Convert the Output from the board form PWM Modulation to DC, an also Step Up Output ESP8266 PWM 0.0-3.3V to DC 0-10V.
Max Current runnig over the Output is 10mA, so I hope not to need external Power Supply.
Is there any ready to use Part for this, which I can order?
Tanks,
Christoph
I doubt there is any ready made part for this. You could use a small dc-dc boost converter to provide a constant 10V supply from 3.3V/5V, then a transistor to boost up the pwm signal to 10V, and finally a low-pass filter to smooth the pwm into an analog DC voltage.
I'd look at an OpAmp, 3.33x gain. You can use a 12V supply if you have it available, do the smoothing at the input side.
Most OpAmps can source 10 mA, pick one that can source/sink 20 mA to have a bit of a buffer.
Hmm, yes. After my post I thought maybe drawing 10mA from the low pass filter would alter it's output voltage. So a better design may be to filter the esp output pin directly to create a 0-3.3V analog voltage, then feed that into an op-amp, because the op-amp will have a very high impedance input, so won't affect the filter's output voltage. Power the op-amp with 12V from a dc-dc boost converter if no other 12V supply is available.
Most 0 - 10V analog inputs draw almost no current so you should be able to use a 4.7k ohm/4.7uF RC LPF.
Great!
Thank You.
But - sorry - I am software spezialist, no hardware. How to wire?
Christoph
RC LPF
creiter:
Did you actually measure that yourself yet? If, in fact, the current is much less than 10mA, like less than 1mA, then the simpler transistor circuit I suggested, along with the RC values suggested by raschemmel, might work. But if 10mA is truly needed, then the op-amp circuit suggested by vwmarle would be better.
This statement makes no sense when discussing a 0 to 10V analog INPUT
(because they are high impedance, as mentioned)
Thank You! I will try it out. Christoph
Some of these 0-10V inputs have the 10V already built-in wit an internal pull-up resistor. That way, you get full-brightness with no connection to the dimming input, or you can just connect a pot for dimming.
So, check with your meter to see if you already have 10V. If so, you can simply connect a transistor (with a current-limiting resistor to the transistor base).
