PWM @ 4MHz
I hope someone can help me with this, I need to generate a 4MHz signal at 50% duty cicle using a PWM pin. It can be any of the PWM pins, can anyone help me with this. Thanks.
Hello CustomDev,
[Notice]Excuse me in advance if i'm out of topic, i started Electronics a week ago, and just received my Arduino 2 days ago[/Notice]
As far as i understand your question, you want to change the frequency from the actual vanilla arduino PWM frequency to a custom one? There would be two distinct solutions, which of course involves that you first look for the actual PWM frequency of an un-hacked arduino. Once you know that, here would be the two solutions which popped into my mind: - Software hack: a fast search gave me this link: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1152547089 It apparently involves hacking a little bit of the wiring software source code and re-compiling it for your purpose. - Hardware extension: Here, two different solutions. Lets's say the Arduino PWM native frequency is lower than the one you're trying to get, you'll need a Frequency Multiplier. If the opposite case (Which i think would be correct), you'll need a Frequency Divider. i have found one which divides by two and preserves duty cycle here: http://analog-innovations.com/SED/Div2PercentSame.pdf. You might be lucky if the native Arduino PWM frequency is a multiple of two of the one you're aiming (Eg. 8 or 16 are both luck), because then you would have to modify those schematics or chain them together.
About this matter, i don't really know where to start, but i found plenty of answers on google.
Again: Please someone not novice confirms or informs my thoughts, i never tried any of that myself.
Pierre.
Thanks for your help, but if anyone needs to do it, this is the code I used to get a 4MHz at 50% duty cicle on pin 3:
pinMode(3, OUTPUT); TCCR2A = 0x23; TCCR2B = 0x09; OCR2A = 3; OCR2B = 1;
With this I get a very nice square wave that I am using as a clock signal for a smart card.
