PWM 9 LEDs(3 RGBs) from an Arduino Pro Mini(328p, 16mhz, 5v)
Hi
I have connected 3 RGB LEDs(1st to digital pin 3,5,6 ; 2nd to 7,8,12 ; 3rd to 9,10,11) with one 100ohm resistor for each LED, and a 10M resistor between pins 2 and 4 for 'capsense' to my Arduino Pro Mini(328p, 16mhz, 5v). I have uploaded the 'pwmallpins' sketch to it and it works fine with the added 'capsense' code.
#include <CapacitiveSensor.h>
long time;        // variable for speed debug
float pwmSpeed[14] = {
 0, 0, 1.2, 1.3, 1.4, 1.9, .9, .8, .5, 1.2, 1.7, 1.3, 0.3, 0};             // these constants set the rate of dimming
int pwmVal[14];                                                               // PWM values for 12 channels - 0 & 1 included but not used
float pwmFloats[14];
int i, j, k, l, x, y, z, bufsize, pot;                                        // variables for various counters
unsigned char sinewave[] =        //256 values
  0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
  0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,
  0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5,
  0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,
  0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,
  0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc,
  0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3,
  0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83,
  0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51,
  0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,
  0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a,
  0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08,
  0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23,
  0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c,
  0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c
CapacitiveSensor   cs_4_2 = CapacitiveSensor(4,2);
void setup(){
  cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
  DDRD=0b11101000;      // direction variable for port D - make em all outputs except serial pins 0 & 1
  DDRB=0xFF;      // direction variable for port B - all outputs
void loop(){
  // time = millis();               // this was to test the loop speed
  // for (z=0; z<1000; z++){        // ditto
  //  pot = analogRead(0);          // this implemented a potentiometer speed control to control speed of fading
  long start = millis();
  long total1 =  cs_4_2.capacitiveSensor(30);
           // check on performance in milliseconds
                    // tab character for debug windown spacing
                      // print sensor output 1
  if(total1>300){
  for (y=0; y<14; y++){             // calculate one new pwm value every time through the control loop
    j = (j + 1) % 12;              // calculate a new j every time - modulo operator makes it cycle back to 0 after 11
    k = j + 3;                      // add 2 to the result - this yields a cycle of 2 to 13 for the channel (pin) select numbers
    pwmFloats[k] =  (pwmFloats[k] + pwmSpeed[k]);
    // pwmFloats[k] =  (pwmFloats[k] + ((pwmSpeed[k]  * 15 * (float)pot) / 1023));    // implements potentiometer speed control - see line above
      if (pwmFloats[k] >= 256){                  // wrop around sinewave table index values that are larger than 256
      pwmFloats[k] = pwmFloats[k] - 256;
    else if  (pwmFloats[k] < 0){
      pwmFloats[k] = pwmFloats[k] + 256;        // wrop around sinewave table index values that are less than 0
    pwmVal[k] = sinewave[(int)pwmFloats[k]];                   // convert the float value to an integer and get the value out of the sinewave index
  PORTD = 0b11101000;              // all outputs except serial pins 0 & 1
  PORTB = 0xFF;              // turn on all pins of ports D & B
for (z=0; z<1; z++){         // this loop just adds some more repetitions of the loop below to cut down on the time overhead of loop above
                             // increase this until you start to preceive flicker - then back off - decrease for more responsive sensor input reads
  for (x=0; x<256; x++){
    for( i=3; i<14; i++){    // start with 2 to avoid serial pins
      if (x == pwmVal[i]){
        if (i < 8){    // corresponds to PORTD
          // bitshift a one into the proper bit then reverse the whole byte
          // equivalent to the line below but around 4 times faster
          // digitalWrite(i, LOW);
          PORTD = PORTD & (~(1 << i));
        else{
          PORTB = PORTB & (~(1 << (i-8)));         // corresponds to PORTB - same as digitalWrite(pin, LOW); - on Port B pins
All the LEDs light up and change colours as long as the sensor pin is touched . I tried programming such that when the cap sensor pin is not touched, the LEDs pause at their current levels, and when touched again the colour change continues. I couldn't figure out a way. Help needed!
